1986 FXSTC Candy Burgandy Color
Have the list back to 87, your maroon looks to be a non-candy color, the center color is candy, maybe OEM custom. Good paint vendors have a scanner that can tell them the paint code by just putting it on a panel. Since it looks like your bike is still mobile, having it scanned is a option if nobody can produce the paint code.
Harley Davidson 1987
Artic White 98603GY
White 98063 AV
Bright Candy Plum 98603 HB/HL
Candy Brandywine 98603 FP/HE
Candy Bronze 98603 HI/HH
Candy Crimson 98603 HJ/HE
Champagne Gold 98603 GZ
Creme 98603 EX
Dark Candy Plum 98603 GK/HL
Maroon 98603 HK
Metallic Blue 98603 HG
Signal Red 98603 GP
Silver Metallic 98603 HB
Vivid Black 98603 DH
Artic White 98603GY
White 98063 AV
Creme 98603 EX
Maroon 98603 HK
Signal Red 98603 GP
This is stock original paint. Both the red and burgundy on the tins are candy. The frame is just a straight color, no pearl or flake. Haven't had much luck with the gun on these sparkly colors... Otherwise I'd just do that, my cousin owns a body shop. I was hoping to get the HD number, then search or original paint or touch up.
Received 3,278 Likes
maybe try www.colormaniapaint.com
Artic White 98603GY
Birch White 98063 AV
Creme 98603 EX
Dark Candy Plum 98603 GK/HL Maroon 98603 HK
Signal Red 98603 GP
Hard to make it look right. My understand is that the paint is a base coat, a number of tinted clear coats to give it depth and then the last protective clear coat. It may even have a lighter colored primer so it lightens the base coat a bit.
That is a similar color to my 1992 FLHTCU that I had to match as close as I could so I could just do a base/clear. Ended up using a BMW color.
You may want to ride up to a paint supplier, take some chips outside and match up something. We tried to do the light meter but it didn't even get close.
