Lifter Question
Old Aug 21, 2022 | 08:48 PM
johnod's Avatar
johnod
Default Lifter Question
97 FLHTCUI
Are you supposed to change the lifters every so many miles?
Thought I read that somewhere.
Thanks
Old Aug 22, 2022 | 04:35 AM
IronAss's Avatar
IronAss
I've heard some say 50,000 miles but as far as I know, there is no recommended time to replace them.
If your bike is a daily rider, it probably isn't a bad idea to have at least a couple spares just in case one should take a **** though.
Old Aug 22, 2022 | 08:32 AM
Racepres's Avatar
Racepres
And, Get them from the guys that replace at 20,000
Old Aug 22, 2022 | 11:18 AM
98hotrodfatboy's Avatar
98hotrodfatboy
If the valve train ain't noisy, leave it alone...
Dan, I was told the 93 up lifters were good. It was the early ones.. I could be wrong but I'm pretty sure that's what I was told by Hillside.
Old Aug 22, 2022 | 12:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If they are oem lifters made before around `96 or so, and you wait for a noise, it will be too late.
It is not the hydraulic part that causes the problem, it is the roller assembly, and when you hear that noise it is time to split the cases.
Old Aug 22, 2022 | 04:12 PM
98hotrodfatboy
As far as I know the b lifters resolved there issues of the early lifters.. I got my info from Hillside..
But OP, if it makes you feel better then replace them .. Myself I like S&S lifters..
Old Aug 22, 2022 | 05:52 PM
johnod's Avatar
johnod
Sadly with my hearing I don't hear a lot of things.
johnod's Avatar
johnod
What are B lifters?
Old Aug 22, 2022 | 06:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
B Lifters are the most recent design for OEM Harley lifters, they came out around 1996 (I think), maybe someone here can be a bit more accurate.
B Lifters are what you will get if you buy new lifters from a dealership.
Old Aug 22, 2022 | 06:10 PM
johnod's Avatar
johnod
B Lifters are the most recent design for OEM Harley lifters, they came out around 1996 I think, maybe someone here can be a bit more accurate.
Thanks, mine's a 97 , so should be good. No idea whats in there as was a cam change by PO,with I assume new lifters.
