Inner primary
Old Aug 24, 2022 | 06:06 PM
garry c.'s Avatar
garry c.
Default Inner primary
I'm going to put mid controls back on my 85 FXR. My question is do I need to loosen the motor and tranny mounts when I put the inner primary back on to ensure a good fit or will it slide right back into place??? Thanks in advance...
Old Aug 24, 2022 | 06:33 PM
Racepres's Avatar
Racepres
I always loosen... always... do Not want to accidently Force, anything. A wood block, and a scissor jack on the lift...simple simon
It just "feels" better....
Edit; The Boys with "shops" will be by to tell us how to cheat the "flat rate".. IDC. My Shop is Mine, for my stuff Only. If it takes me a bit longer... Oh Well
My Time, I spend it how I wanna..
If yer in a hurry.... Say.
Old Aug 24, 2022 | 06:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Old Aug 24, 2022 | 06:46 PM
garry c.'s Avatar
garry c.
Thanks guys, the answer I was looking for. I always did on the Shovel so I figured as much.
Old Aug 24, 2022 | 07:42 PM
Yankee Dog's Avatar
Yankee Dog
Don't forget any exhaust brackets or other items besides the engine mounts that might interfere with engine or trans movement. Had that happen to me. Your trying to align everything into place so the easier you make it for movement the better the alignment will be.
I have a suspicion that issues some guys have had with the broken raised lip on the engine by the stator at the large O-ring could be caused by bad/improper alignment. The easier it is for the primary bolts to draw the inner primary, engine, and trans into the proper locations, the less tension on that lip or inner primary. Less chance for leaks also.
Old Aug 24, 2022 | 08:27 PM
Racepres's Avatar
Racepres
Oh My Yes... Double Yes.. certainly exhaust, as on an FXR one pipe is held by the engine, and one pipe by the trans!!!
Thank You YD
Old Aug 25, 2022 | 07:00 PM
carlgrover's Avatar
carlgrover
I don't know how it is on your bike but on my 98 rkc there are pretty detailed instructions in the fsm for putting the primary back on. The motor, trans, and rear sprocket all have to be lined up just so.
carl
Old Aug 25, 2022 | 07:07 PM
Racepres's Avatar
Racepres
carl
Yest.. it is like that...But, I just wiggle and twist etc...til it Snicks together... Never force anything... when you least expect it... it flops together perfect!!
Craigsameer
Nov 30, 2021 01:33 PM
rideevo
Mar 17, 2013 05:50 PM
dues
Jul 23, 2012 02:02 PM
