Alignment
small changes - air up the tires - and an eye level to look at and compare - yea a measuring tape is also in play but your eyes are as well
use a magnetic angle finder, <10 bucks at Harbor Freight.
put on front brake rotor and adjust your tie downs until it reads 90 degrees.
Put angle finder on rear rotor then adjust top mount to until it reads 90 degrees.
One thing I did discover is how much wider a Michelin Commander II front tire is than the rear, almost 1 inch!. I'm sure it has something to do with the 3.5" wide RK Excell rims spreading the tires out a tad more than the stock 3" rim, but it was still a shock. I would really like to run a smaller ( narrower) front tire in the future If I can find a suitable one. That front barley fits in the fender.
Try this (it's a bit of a chore, but what else you gonna do?): Disconnect both the top and the front stabilizers. Remove the tank. take a ratchet strap and run it over the backbone and under the motor. Tighten it up until it is carrying the weight of the motor. Jack up the bike so the rear wheel is off the ground. This next part is a bit of a gut check, depending on how much you trust your jack, but grab the front of the motor (more or less where the front stabilizer mount is) and give it a few shakes. The idea is to get the donuts to settle in to their "happy place".
When I installed the Glide Pro system, I had the exact same problem you described. Called Jake, and he recommended the above procedure. Worked like a charm.
1 - Trust me, nothing you did would have thrown the frame alignment off much at all from the factory setting. But definitely a good idea to check/adjust after rear fork bearings. Going over one that's just been built and/or wrecked is a different story altogether. So, start over. Put the adjusters back to the lengths they were, as best you can guess.
2 - If the rear wheel is not perfectly aligned with the swing arm pivot axle, you'll be forever and get nowhere. That has to be perfect before you start anything else.
3 - You cannot trust a level or laser reading off the front disc. If you set the level so it's zero'd vertical, move the bars 1/8 inch, the bubble changes. So level the frame underneath near the main cross member, left to right then check at the rear disc for the top link adjust.
4 - You're gonna have to arrange some way to hold the bike up level left to right and have the ability to turn the handle bars slightly plus actually see and touch both sides of both tires. A jack or a board and 2 cinder blocks... something. You will never be able to do a frame alignment with the front wheel in a clamp.
Watch this video (it's not mine). You'll then understand why you can't use a wheel clamp, how terrible the FSM is at explaining how to do it all and that a 15' piece of mason twine or fishing line is all you need to do the front adjuster alignment to get both wheels running true. Straight edges on a Tour model with wider front tire just don't work for me.
String is quick and easy but I couldn't find the exact video I wanted that shows a guy actually doing it on your model. Here's some pics that'll give you some ideas. Just remember on yours - string or straight edge must touch 4 points on the front tire regardless and if using string rather than straight edges, the string mus contact 2 points on the rear (back of tire)
IENATSCH TUESDAY: How to Align Your Motorcycle Wheels with "String" | Cycle World
