Alignment
1 - Trust me, nothing you did would have thrown the frame alignment off much at all from the factory setting. But definitely a good idea to check/adjust after rear fork bearings. Going over one that's just been built and/or wrecked is a different story altogether. So, start over. Put the adjusters back to the lengths they were, as best you can guess.
2 - If the rear wheel is not perfectly aligned with the swing arm pivot axle, you'll be forever and get nowhere. That has to be perfect before you start anything else.
3 - You cannot trust a level or laser reading off the front disc. If you set the level so it's zero'd vertical, move the bars 1/8 inch, the bubble changes. So level the frame underneath near the main cross member, left to right then check at the rear disc for the top link adjust.
4 - You're gonna have to arrange some way to hold the bike up level left to right and have the ability to turn the handle bars slightly plus actually see and touch both sides of both tires. A jack or a board and 2 cinder blocks... something. You will never be able to do a frame alignment with the front wheel in a clamp.
Watch this video (it's not mine). You'll then understand why you can't use a wheel clamp, how terrible the FSM is at explaining how to do it all and that a 15' piece of mason twine or fishing line is all you need to do the front adjuster alignment to get both wheels running true. Straight edges on a Tour model with wider front tire just don't work for me.
https://www.youtube.com/watch?v=Mp4_wIUeTic
String is quick and easy but I couldn't find the exact video I wanted that shows a guy actually doing it on your model. Here's some pics that'll give you some ideas. Just remember on yours - string or straight edge must touch 4 points on the front tire regardless and if using string rather than straight edges, the string mus contact 2 points on the rear (back of tire)
IENATSCH TUESDAY: How to Align Your Motorcycle Wheels with "String" | Cycle World
Yes the Swingarm isolators are indexed on the pins correctly.
Yes, I use the recommended tool from the FSM to correctly align the rear wheel in relation to the swingarm pivot. I made one and purchased another from Motion Pro. This was done before anything else.
The Michelin Commander II front tire is so much wider that the rear it does make things harder, but it can be done ( and I did it.)
To make sure the handlebars were pointed perfectly straight ahead I measured from a fixed point on each fork ( bottom drain bolt ) to fixed point on the frame on both sides and adjusted accordingly. To get the back of the bike in line with the front I started with the eyeball method, then used an 8 foot straightedge to square it up as perfectly as possible.
Instead of using bubble levels or the lasers which both turned out to be problematic I used magnetic base angle finders (3) one on each disc and one on frame to determine 90 degrees and 0.
My bike was not set up at the factory. Early in it's life it was involved in an accident which required frame replacement, I purchased the bike right after this as a roller to build the current bike. Unfortunately on it's first test ride after spending a winter building it I had a Buick station wagon turn left right in front of me, again bending the frame and forks. Frame replaced again at same dealer, guys insurance paid for all the custom parts like wheels, brakes etc. During the frame swap the second time I had many issues with the quality of the work performed at the dealership, lots of loose nuts and bolts and just sloppy work in general. I've been attempting to make it handle better ever since.
After re-checking everything again and starting from the beginning again, I was finally able to get everything into near perfect alignment, no more than .5 degree off in any plane. The top and front adjusters required lots of adjustment to get it right but now the front engine mount is seated correctly and everything is in alignment.
I am a perfectionist and have been known to obsess over details to the point of affecting my mental health. I am confident this time it is as good as it can get. And i'm tired of messing with it.
I always say, doesn't matter how you get there so long as the finished product is near to perfection as humanly possible. My compliments for staying with it. 👍
Suspension set up:
Front forks: Race Tech emulators, Race tech springs, Bel Rey 12wt oil.
Rear shocks: DS adjustable length premium set at 13"
Braced rear swingarm with spherical bearing kit and Glide Pro mounts
Custom third link
Rolling Stock:
RK Excell chrome Aluminum 3.5" rims, Buchannan's polished SS spokes, Ness billet aluminum hubs. Michelin Comm. II stock sizes
Front brakes PM 6 piston calipers with EBC floating rotors, PM master cylinder. Rear stock rebuilt caliper and master, floating Harley rotor, braided SS brake lines F+R
The power train alignment tools get you in the hunt very quickly to begin with, then you can tweak from there as needed.
