Leaks - Transmission
So I previously (anotjer thread) had a transmission and other leaks that prompted me to replace gaskets and seals for the F and R cylinders, transmission cover, inner and outer primaries, jackshaft and transmission seals.
Leaking again like a sieve from the transmission. Not sure what I'm missing, but obviously something. The transmission reservoir was extremely low after my recent trip.
Thought/comments?
Thought/comments?
Did you replace the quad seal. That seals the inner input from the outside drive shaft.
Years ago, on bikes with chains, there wasn't one. Only thing that sealed them was the spacer faces.
Been a long time (probably 20+ years). But that's how I recall it. Either that or the needle bearing are gone on the input shaft if you think the main drive bearing is OK
After going through your previous post, I would suggest cleaning it up. Filling the transmission about 3/4 full of oil to get level way up on stick.
Put a light pressure on the vent tube.
You should spot the leak. Be sure to drop level in primary afterwards since that full with pressure is also going to push oil there also.
