Guys, I installed a new front brake switch on a '90 Heritage.. I'm having trouble keeping the metal push rod in contact with the plastic pin (switch). After about 5 or 6 pulls on the front brake lever the metal push rod loses contact with the pin and the brake light stays on. The pin is item #3 below and a metal push rod is part #30 at the bottom. Any tips? It seems the metal push rod moves / rotates too easily.
I respectfully disagree. I never bend anything on an Evo switch.
Loosen the switch housing and move it toward the brake housing. You have to play with it a bit to get it like you want. Too close and it won't come on, too far away, stays on. Only have to slide the housing/throttle a tiny bit to make a big difference in when light comes on.
I installed a pressure switch and that cured the problem.
That tab #30 almost always needs tweaking when aftermarket stuff gets used. Don't kid yourself.
Yiu don't bend the switch, you bend the tab on the brake lever, that is how you adjust them.
