starter?
Old Sep 3, 2007 | 06:53 PM
billb's Avatar
billb
Stage I
Default starter?
Pressing the starter button only gets "clicks". Battery is okay. Headlight does not dim when "clicking" occurs. Bike will push start okay. Does this sound like the starter is kaput?
Old Sep 3, 2007 | 07:24 PM
1yrb4hd's Avatar
1yrb4hd
Banned Camp
Default RE: starter?
I just went thru this with my 89 lowrider. My bike did the same thing, I put the bike in the shop some 7 weeks ago and still havent gotten it back. Apparently Harley had a bad run of starters, the entire run was bad.
2 bad starters from HD and 1 bad aftermerket later I had mine rebuilt, I'm told the bike is fine now...( hoping to pick it up this week )...geet yours rebuilt man.
Old Sep 3, 2007 | 07:39 PM
HD7585's Avatar
HD7585
Maybe a soilnoid or relay problem
Old Sep 3, 2007 | 07:57 PM
hotrod351's Avatar
hotrod351
sounds like a bad connection. bad ground on starter or bad hot.
Old Sep 3, 2007 | 08:44 PM
Y2K's Avatar
Y2K
Check your connections especially the grounds and buy a new starter relay before replacing any other parts,
Old Sep 4, 2007 | 10:10 AM
greezymonkee's Avatar
greezymonkee
For a little light reading....
Check out the link for "click of death" in this forum.
Been working through a similar issue for a bit now. Still working on it.
GM
Old Sep 6, 2007 | 04:10 AM
Stkman's Avatar
Stkman
Had a simler problem, a friend said to shoot some contact cleaner in the starter switch on the handle bar and after doing that the damn bike started fine for about 2 weeks or after I would wash it. You might try that and see. I installed a low down switch on the starter to alliminate that problem.
Old Sep 6, 2007 | 09:12 AM
DirtyDave's Avatar
DirtyDave
ORIGINAL: Y2K
[sm=exactly.gif]Always start with the simple/inexpensive stuff first. A loose battery connection will do it. A bad relay, loose connection to the starter, dirty or wet switch in handle bar.........
Old Sep 6, 2007 | 01:34 PM
jhnmflr's Avatar
jhnmflr
Relay's are very common , try simple , simple , simple 1st
Old Sep 6, 2007 | 01:45 PM
86eglide's Avatar
86eglide
4th Gear
I had same problem with my 86 flht. Battery good, new starter, still just clicked at times, ended up the wiring had just got old, had a push button placed down at starter and had no problem since. The shop said they could replace the handlebar switch, but with the old wiring in a bike that old it would just still be a problem. Sometimes the handlebar switch works, but it really spins over fast with the switch right at the starter.
