VOES question
Old Aug 22, 2025 | 03:17 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Originally Posted by Rains2much
I’ve never ran Voes before.. last cam swap I did was a ev27 and put an S&S E on it. It’s hard to start.. and runs hot. I think the carb is set perfect, plugs look good, but a tad hot. I static timed the 2000i and hooked the Voes up like he had before. I didn’t change the programming.
Now I’n debating… should I retard the timing a degree or two or just take that Voes off and program the 2000i as it should be with no Voes?
(Stock 1998 Dyna wide glide with ev27, S&S E, drag pipes with baffles.)
Define running hot.. Did you take a temp reading of the cylinders? 280-300 is totally acceptable. Set ignition to curve 2..
Old Aug 22, 2025 | 03:32 PM
98hotrodfatboy
Deleted, Wrong thread.....
Old Aug 22, 2025 | 03:35 PM
t150vej's Avatar
t150vej
He has the L84-'89 clutch and it does use 3/4 turn.
Old Aug 22, 2025 | 03:40 PM
98hotrodfatboy
@t150vej I understand what the FSM recommends but don't always believe it what the MOCO suggests.. Even the later clutch setup from 98 up says to adjust the screw till all free play is taken up on pushrod.. Then back off adjuster screw 1/2 to full turn and lock down. I personally feel this is too much and is the reason that it's difficult finding neutral at a stop, With it adjusted this way it doesn't seem to move the pressure plate enough to release the frictions enough and this is why I've always set my adjustment to 1-2 flats without burning any of the steels, ever.. And with that it was only moving the pressure plate .068" which I felt was not enough.. To each their own I guess..
Old Aug 22, 2025 | 03:58 PM
Rains2much's Avatar
Rains2much
no.. just a 15 mile ride and the bike was really warm. It stayed warm for hours after parking. You could mildly burn your hand if you rest it on a rocker box. Hotter than my 127 after a 10 mile ride. It runs beautiful other than a rougher idle at low rpm. I don’t have a thermal gage and he doesn’t have an oil temp gage on the bike.
I don’t think it’s lean though. The plugs are even and right. It ran like crap with the 29.5. The mixture screw was just about all the way in.
Old Aug 22, 2025 | 04:08 PM
98hotrodfatboy
Sorry wrong thread...
I don't know how i keep mucking up in the wrong thread..
Old Aug 22, 2025 | 04:36 PM
t150vej's Avatar
t150vej
There's a lot of the same subject going on. Lol I knew what you were replying to.
Old Aug 24, 2025 | 01:06 PM
Rains2much's Avatar
Rains2much
No worries.. I didn’t want ask around in someone else’s thread so I started my own.. but yes, redundant.
Hyper2005LR
Product Reviews
Jul 27, 2006 10:34 PM
