python exhaust
Old Sep 29, 2025 | 04:23 PM
mdkelley's Avatar
mdkelley
Default python exhaust
I just picked up a set of what I am pretty sure are python true dual header pipes off a 2005 ultra but the guy didn't have mufflers. Does python have a custom size for their mufflers? I have a pre 94 and post 94 style mufflers in the garage and both are too small, just slip inside. Anyone familiar with python pipes and know what will fit or if these are some strange python-only custom size? I assumed any set of HD stock slip on mufflers from that 2005 era would fit but maybe not? The header pipes appear to "step up" in size.
measured them, just shy of 2", like 1 15/16 maybe. Guy said he had fishtails on the bike... maybe i have to cut a slot and slip mufflers inside and clamp? I can slide the newer style in an inch or so, probably just do that unless good reason not to. Looking forward to getting these on so i can put my lower farings back on.
Old Sep 30, 2025 | 05:41 AM
Architect's Avatar
Architect
Just info, I see ports for O2 sensors which a 2005 would not have from the factory. Maybe the after market head pipes are later or for a different year bike? Just something else to think about, good luck.
Old Sep 30, 2025 | 07:02 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Cutting a slot in them seems like a good way to get an exhaust leak.
Old Sep 30, 2025 | 11:42 AM
RANGER73's Avatar
RANGER73
Python's are Vance & Hines rebranded for Drag Specialties.
Try contacting Drag Specialties.
The Big Shot baffles should fit. I have the Big shot staggered
Both V&H and Python, they're 2".
Old Sep 30, 2025 | 12:28 PM
Rains2much's Avatar
Rains2much
I think those are Bassani 3 step tuned pipes. There are two different Bassani inlet mufflers… those would be the large size.
‘’Those pipes are rare and make better power than the 2 into 1 pipes while being true duals. Those are awesome pipes.
Old Sep 30, 2025 | 01:34 PM
mdkelley's Avatar
mdkelley
thanks for all the info. I thought the guy I bought them from said he had them on an 05 ultra. He probably just plugged the sensor holes, same as I would have done. He crashed the bike but removed the pipes before turning bike over to insurance since he said they were expensive. I will see if I can find any bassani mufflers but doubtful any used ones come up cheap around here. I was going to just slip in some stockers and clamp it tight, would probably be fine. If I can find mufflers that fit for not too much $$ I may go that route but do want to keep the noise down.
Old Sep 30, 2025 | 01:40 PM
Rains2much's Avatar
Rains2much
You probably wont…. Those larger size mufflers are extremely rare. Hoping the best in your search.
Old Sep 30, 2025 | 01:54 PM
Architect's Avatar
Architect
Bassani is still in business and sells mufflers, worth a phone call:
Bassani Xhaust - Slip On Mufflers
Macksun
Oct 9, 2019 04:15 PM
pierrat63
Feb 14, 2017 10:04 AM
sloans4x4
Aug 25, 2013 06:09 AM
zyban
Aug 12, 2013 07:01 AM
Idaho Scootertrash
EVO
22
Jan 3, 2013 01:23 PM
