Crankcase ventilation pros and cons
Old Nov 3, 2025 | 10:44 PM
randallissimo's Avatar
randallissimo
Default Crankcase ventilation pros and cons
My bike came to me with crankcase vented to atmosphere via a hose to bottom. My intake is oil free. Then I heard Kevin Baxter at Skunk Works explain that while doing that is great for the intake and pistons, it is also defeating the vacuum assisted crankcase ventilation that the motor was designed with, which can cause issues with the oiling system.
I am interested in knowing more about this, partly because I am having an odd oiling system thing going on with my bike as well. So I would like to hear some views on this.
Venting to atmosphere, good or bad?
Old Nov 3, 2025 | 11:57 PM
chief08's Avatar
chief08
tell us about your problem. old cars in the fifties use to vent to atmosphere and no problem. then came the EPA
Old Nov 4, 2025 | 05:48 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Don't believe everything Baxter says.. I run both top and bottom and breathers.. less crankcase pressure.. I could give a **** less about the EPA...
Old Nov 4, 2025 | 07:45 AM
randallissimo
The EPA didn't come along until the early 70's. And I don't think they told manufacturers how to build their engines, as in how they had to deal with crankcase fumes. But they did tell them here are the emissions numbers you need to hit from now on. The manufacturers did the rest. Policy aside, I'd like to know how/why venting to atmosphere effects other things in the motor.
Old Nov 4, 2025 | 07:56 AM
Joe12RK's Avatar
Joe12RK
I can't see how moving the hose out of the air filter housing and into the open atmosphere makes any difference at all to crankcase vacuum. The air filter is at atmospheric pressure or it would hurt performance.
ps, If you want to play around, add a one-way canister in the vent line to keep vacuum in the crankcase.
Old Nov 4, 2025 | 08:03 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I cant see how venting to atmosphere would affect vacuum. The carb is still breathing through the air filter, and the small holes where the hoses go through the back of the carb plate are sealed off.
Old Nov 4, 2025 | 08:19 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Positive crankcase ventilation actively draws blow by fumes out of the crankcase. An overboard discharge leaves the crankcase full of fumes, with basically only the excess being pushed out via the overboard discharge.
One can create a bit of a venturi, to help pull the fumes out while the vehicle is moving, by positioning the end of the discharge hose to a low vacuum area. The effect is small, but it is real.
The crankcase fumes contaminate the crankcase oil, and use up the additives in the oil that combat this contamination. You may even see the oil darkening earlier because of this.
The effect on oil was much worse long ago with carburetors and chokes. Today, with active fuel injection, the engines burn far more cleanly, and blow by contaminants are greatly reduced.
Old Nov 4, 2025 | 08:48 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Venting overboard causes zero issues with the oiling system of a Harley Davidson engine.
Old Nov 4, 2025 | 09:21 AM
randallissimo
There you have it already, hardline opinions on both sides of the discussion. They can't all be right. For those who say they can't see what difference it makes relative to vacuum, that's easy. Sure the carb is at atmosphere, but we are talking about intake vacuum here from cylinder suck. Hell, that is how many car dashboard vent functions worked, or at least used to. So, yeah, it makes a difference.
Oil consumption and new oil going black really fast are two of the issues I have on this bike with 135 psi compression. Basically wondering how and if this lack of vacuum crankcase situation is playing a part in that.
Old Nov 4, 2025 | 09:27 AM
98hotrodfatboy
honestly with only 135 PSI cranking pressure I would say that you're getting way too much carbon down into your oil via the Rings, so don't be blaming it on engine venting..
