Squeak when decelerating
Old Oct 17, 2007 | 10:12 PM
vtarandy's Avatar
vtarandy
2nd Gear
Default Squeak when decelerating
I just turned fifty and finally got my Harley, it's a 93 FLHTC with 24,000 on it. It has just developed a high pitched squeakin noise when I back off the gas. Kind of reminds me of a loud hamster wheel. Has anyone had this problem?
Old Oct 19, 2007 | 07:59 PM
93FLHTC's Avatar
93FLHTC
Stage I
Default RE: Squeak when decelerating
I too just bought a 93 FLHTC. It had squeaking sounds that turned out to be loose bolts. The bolts holding the saddlebag guards on were loose. I also found that the mount for the mufflers, the rubber one would squeak but a shot of WD40 took care of that.
Old Oct 20, 2007 | 08:35 PM
txfxstrider's Avatar
txfxstrider
I had that same situation and thought it was my S&S whistling when I let off the throttle. Turned out to be my belt needed adjusting.
Old Nov 4, 2007 | 08:27 PM
Sillverback's Avatar
Sillverback
Yep...it's the secondary drive belt. Just needs to be adjusted.
Old Nov 5, 2007 | 11:10 AM
fxstcguy98's Avatar
fxstcguy98
Mine started to do that and I pulled the rear wheel and packed some grease in the wheel bearings, I plan on taking it apart this winter and do a proper repacking.
Old Nov 8, 2007 | 02:45 PM
Fatboy931's Avatar
Fatboy931
Make sure the pulley on the tranny is tight. My 93 FLSTF snapped the retaining screws and the nut backed off. It sounded like a squeak. Ruined the output shaft on the tranny.
Dalisword
Oct 3, 2012 01:47 PM
tennessee streetglide
Jul 30, 2009 11:43 AM
shovel89
Jan 21, 2009 02:23 PM
vtarandy
Oct 18, 2007 06:27 AM
LuckyRoadKing
17
Aug 15, 2006 06:26 PM
