I got one for the ols sporty off ebay and the fitting isntuctions aslo had big twin in them as well so yep they are out there. Sounds like you have a little bit of clutch drag ksscooter try adjuting the free play up in your push rod.
I put the reduced effort kit (36808-05) on a '99 softail. If your '98 touring bike has the late model clutch it will fit. There wasn't very much differance in the softail ramps compaired to the kit ramps, but the kit ramps were a littl lower wich makes for less effort. Combined with the spring it is an improvement. Add the teflon line cable and get evenmoere improvement.
Does Harley make a reduced pull clutch kit for my 1998 evo Road King?
Thanks,
Richard
If you want something inexspensive and easy to install, try an EasyPull kit. Goes in the trans.case at the clutch cable hookup. Reduces pull about 40%, can get from JirehCycles for less than $10.00. I installed one on my 95flht/evo 2 years ago.Helped alot, especially in traffic.
