Should I have a Dyno tune done?
I'm curious as to whether this is really beneficial. I need an accurate tune on my carb'd Dyna. I'm not interested so much in making sure I get every bit of power out of my ride. I'm not concerned about the stats. \\; I just want it to run correctly.
It's stock except for the a/c and slip-ons. It is running rich, and the guy tuning it hasn't done it right (IMO) because of the 30mpg I get and carbon build-up.
I have to get it tuned, one way or the other, by somene who knows/cares about what he's doing... \\; \\;
RE: Should I have a Dyno tune done?
Dyno tuning will make it no better mileage wise. They only know how to tune for maximum performance.
You should be in the jet range of 45 - 48 low and 165 - 175 main jet. Assuming the timing is good, only other things that will make it sloppy rich are a high float level, bad enhicher valve/cable or horribly maladjusted idle mixture screw.
here are 3 link that will clue you in how to get it right.
http://www.harley-performance.com/ha...arburetor.html
http://www.harley-performance.com/ha...r-jetting.html
http://www.cyclespot.com/Jetting.html
