replacement engine
Old Jan 27, 2009 | 10:49 AM
hotrod351's Avatar
hotrod351
Default replacement engine
i ahve a 1990 fxstc with semi stock motor. which motor, S&S or ulbruto, would be a direct replacement, i want to be able to use my bdl 3" open primary and stock tranny, plus my vance & hines longshots without doing any modifacations. i dont want to get an engine and find out the pipes wont hookup right or anything else. im thinking about a small S&S, say 95" or smaller.
Old Jan 27, 2009 | 12:50 PM
sqdealgeorge's Avatar
sqdealgeorge
Either motor will work S&S are bigger $$ I run 96 CI S&S motors Get ready for more vibration and great power
Old Jan 27, 2009 | 01:28 PM
lowglide88's Avatar
lowglide88
you can get an Ultima engine 80 ci-127 ci for $3600.00..check out www.jirehcycles.com
Old Jan 28, 2009 | 05:10 AM
grbrown's Avatar
grbrown
I fitted an S&S V107T in my 1990 FLHS, with the original primary. I am sure you can buy an Ultima complete with open belt and tranny as a complete bolt-in package.
S&S has an extensive catalogue on their website full of illustrations which might answer your questions on fitting one of their engines. Both S&S and Ultima are on the phone!
As for size of engine the Ultimas are cheaper to buy than S&S, so you can have a larger Ultima for similar money. You'll find most people here on HDF have new engines that have a '1' in front!
Old Jan 28, 2009 | 07:08 AM
miacycles's Avatar
miacycles
Any of the Ultima motors(127 or less) will be a direct boly-in. I would also reccomend upgrading your clutch if you haven't already and replacing your starter at the same time.
If you have any questions please feel free to contact me as we have installed a number of these engines.
Old Jan 28, 2009 | 09:31 AM
hotrod351's Avatar
hotrod351
i didnt even think about the starter. seems in the long run its better to just buy the whole package, motor, open primary, tranny and starter. i see the setups on ebay for under $5,000.00
Old Jan 30, 2009 | 05:14 AM
grbrown's Avatar
grbrown
I still have the original 1990 starter on my bike, but the S&S decompressor valves on my 107 are automatic. This engine actually starts more easily than my previous 89 inch stroker, which needed a super strong battery when newly built! I do have a Barnett clutch spring on the original clutch now, to deal with the extra torque of the S&S (102 ft.lbs!).
Ultima engines have manual decompressors and I gather that once run in a stronger starter will turn them over without using them. Hopefully an Ultima owner can chip in?!
Blue Tick
Nov 20, 2016 09:22 AM
upland117
EVO
Jul 14, 2014 09:30 PM
nellis003
Exhaust System Topics
Feb 15, 2013 09:51 PM
Saikia
Sep 12, 2006 12:31 PM
roach
22
Sep 7, 2006 01:41 AM
