Brake light question
Old May 28, 2009 | 09:20 PM
bad466's Avatar
bad466
Default Brake light question
I know this probably isnt the right place for this question but this is where knowledgebase is for the older bikes. I have an 85 FLHT and Im pretty sure my brake light is stuck on, they do nothing when you hit the brakes. Any help would be appreciated, I hate electrical problems.
Old May 28, 2009 | 11:32 PM
shovhd's Avatar
shovhd
If your brake light is stuck on, it's probably your switch housing not being close enough to your front brake lever. There is a normally closed switch that sticks out of the switch housing. A little lever on the brake lever housing holds it in (open position). When you use the front brake, the lever lets the switch out closing the circuit (light comes on). Sometimes the little lever gets worn out and starts walking around inside the housing, missing the switch. I had to drill a hole in the end of the lever and screw a small washer on to it. Fixed my problem.
Old May 29, 2009 | 08:49 AM
Dr.Hess's Avatar
Dr.Hess
Or one of the two switches is shorted. Does that bike have anti-dive? I don't remember what year they started. Is there an air fitting on the crash bar? If so, is there a "click" from the front when you turn the power on? Also, make sure that both elements in the 1157 tail light bulb are lit, which will tell you for sure that the brake circuit is on.
Old May 29, 2009 | 12:23 PM
bad466's Avatar
bad466
Yes there is a click when you turn the switch on and the air fitting is on the crash bar.
Old May 29, 2009 | 12:56 PM
Dr.Hess's Avatar
Dr.Hess
Well, sure sounds like your brake light circuit is engaged then. Try this: Reach underneath the right side of the bike for the two flag connectors on the pressure switch that screwed into the rear master cylinder. Pull the flag connectors off the switch and see if that changes anything. If not, I'd look at the front switch next.
Old May 29, 2009 | 02:05 PM
mjunk1's Avatar
mjunk1
Had a similar problem when I bought mine used and finally found it was the front switch housing had just eased away from the lever. There was just about 1/4 inch gap in there and that was keeping the lever from holding the switch open when the lever was at rest. I'd sure take a close look there as it is a bit counter-intuitive.
Old May 29, 2009 | 05:55 PM
t150vej's Avatar
t150vej
I have that problem 5 out of 10 times I take that side apart for anything. Always my error. Position of the lever housing relative to the switch housing is very important
Old May 29, 2009 | 08:34 PM
bad466's Avatar
bad466
Thanks guys, im gonna check the switch housing in the morning.
Old May 31, 2009 | 10:30 PM
bad466's Avatar
bad466
You guys were right on, a little adjusting on the switch housing and im back in business. Thanks, guys.
103bob
Jul 4, 2016 07:24 PM
BuckeyeRider
Nov 26, 2011 04:56 PM
eisterd
Mar 18, 2011 08:33 PM
Bobber Jay
May 7, 2009 06:47 PM
LT753
Dec 26, 2005 09:00 PM
