Hitachi Starter Replacement
Old Aug 8, 2009 | 09:07 PM
super-snake's Avatar
super-snake
4th Gear
Default Hitachi Starter Replacement
With 10:1 compression on my '84 evo FXRS, the OEM starter just doesn't cut it. Anyone have experience with the Ultima 1.4kw starters?
Old Aug 9, 2009 | 08:41 AM
miacycles's Avatar
miacycles
We have one on our 93" stroker and it spins that over.
Old Aug 9, 2009 | 01:26 PM
super-snake
4th Gear
Thanks - it's on order. I'll report back after installation
Old Aug 9, 2009 | 03:44 PM
megawatt's Avatar
megawatt
I have a 10:1 S&S Evo in a '79 FXS. At every start the Hitachi starter worked very hard to spin it past the first compression stroke but it cranked okay after that. I switched to an All ***** super-wizz-bang starter and I am having the same result (it does spin it faster than the stocker). I tried all the tricks All ***** suggested to no avail. I am not complaining...it seems to be the nature of the beast. If I ever pull the heads, I will have compression releases installed to see if that does the trick.
Good luck with the Ultima starter.
Old Aug 25, 2009 | 01:08 PM
super-snake
4th Gear
I've installed the Ultima 1.4kw starter. It does grunt a bit on the first stroke, but spins pretty good from there. I agree with megawatt - that first stroke is just tough. I wonder if a cam with longer open valve duration would help - I run an Andrews 27 cam.
Old Aug 25, 2009 | 10:34 PM
Fatboy931's Avatar
Fatboy931
A little longer duration will help with the cranking pressure. I had 80 in my Fatboy and there was a noticeable difference between an EV-27 and a V-Thunder 5010 I was running. The exact same starting system is turning over my 113 Ultima with or without the compression reliefs.
Old Aug 26, 2009 | 07:18 AM
miacycles's Avatar
miacycles
Yep, put a little more duration in that puppy and it will reduce the dynamic compression ratio. That should help solve the problem. Also what are you using for cables?? The heavy duty cables can help with the initial voltage drop. Running a ground cable from the frame to the engine will help too. Does your ignition allow you to kill the spark for the first few revolutions?? Hope this helps.
Old Aug 27, 2009 | 03:32 PM
super-snake
4th Gear
Using aftermarket 4 gauge cables. I have checked voltage drop on both + and ground cables and it is minimal. I'll validate with my new starter and consider frame-engine cable - thanks. I use a creane Hi-4 ignition which I believe kills the spark on the first stroke.
Old Aug 27, 2009 | 04:04 PM
miacycles's Avatar
miacycles
Make sure that the ignition is set for electric start, if not change it. If it is try it the other way if you still have problems. If changing it to kick start doesn't change anything then run it in electric start.
98hotrodfatboy
EVO
May 11, 2017 08:27 PM
98hotrodfatboy
EVO
Dec 13, 2015 07:52 PM
hammie
Nov 9, 2011 06:58 AM
918superdave1
Dec 19, 2009 06:31 AM
Dragon Rider
Classic
Apr 23, 2008 01:50 PM
