New Ride!
I purchased a 91 FXSTS over the weekend that is in great shape. It has 12000 miles so it looks new! My question is what is recommended for maintenance after a winter storage? I'm assuming oil filter, crank, primary and trans oils. Unfortunately I wasn't able to find out the brands or weights of fluids used so any advice would be appreciated. I figure worse comes to worse I take a drive to the local dealer. Should I adjust the primary chain? Also the brakes both squeel a little and have descent amount of pad left is that just a matter of putting a few miles on them to get rid of glaze? Are there any areas on an Evo that require regular tightening that you know of? Thanks for answering the newb questions,
Congrats on the ride, I have an 89 springer, you'll like yours. I run 20-50 in the motor, atf in the primary, and 80-90 in the tranny. Get a genuine Harley service manual for it, it will tell you all you need to know. Wouldn't hurt to pack the wheel bearings also, check belt tension, clean plugs, air filter, put in a fuel filter, just the usual stuff. We need pictures.
Bob
Bob
matt_eglide
Jun 15, 2018 06:55 PM
Breeze1962
General Topics/Tech Tips
Feb 25, 2017 08:18 AM
