help with bad vibration
Old May 26, 2010 | 12:56 PM
jturosky's Avatar
jturosky
4th Gear
Default help with bad vibration
89 FXR. I'm getting a vibration at my feet and handle bar. I've replace front motor mount Can someone tell me if the stablizer ends should move or should they be ridged, my ends are ridged and stiff
Old May 26, 2010 | 04:50 PM
jturosky's Avatar
jturosky
4th Gear
To add to my first post. I had the engine off the frame over winter to replace rocker covers, and paint engine. I followed book on install with all the torque specs. I have checked all bolts I can think of. Could it be in primary area,that is the only thing I could think of that I haven't tried yet.
Old May 26, 2010 | 08:44 PM
ozzie65's Avatar
ozzie65
Make sure your alignment is correct. I did an engine rebuild 2 years ago, and if you do not have the alignment correct, you will get/have excessive vibration. I was out approx 1/4 inch on the top mount.
Old May 27, 2010 | 05:55 AM
jturosky's Avatar
jturosky
4th Gear
What do you mean alignment. The front motor mount went on with no problem and top and bottom stablizers are one
Old May 29, 2010 | 07:13 AM
ozzie65's Avatar
ozzie65
Perhaps your bike is different, but on my '86 FLHTC, (rubber mount motor) the top (and bottom) has an adjustable linkage to align the motor.
Old May 29, 2010 | 07:43 AM
t150vej's Avatar
t150vej
The stabilizer ends should (and will) move or more correctly, swivel. The inner bushing is curved on the outer diameter and the outer ring is cupped around that bushing with rubber (or something) between the two. They are very stiff and basically shouldn't move by hand without a bolt or bar as a lever. They don't swivel much, just to allow for the slight angles of the mounting bolts and the ends on each link should be either flat (top mount) or at 90 degrees (bottom front link) If they are in a bind so the outer ring is jammed against the mounting bolt they will cause a vibration.
Did you have the vibration before replacing the mount and did you use an OEM or aftermarket engine mount? Did you align the rubber mount itself per the Service Manual?
Old May 29, 2010 | 11:57 AM
jturosky's Avatar
jturosky
4th Gear
The mount is oem, but the stabilizer ends don't move at all i'll have to start with that. I'll also have to find more info on the alignment process of checking and or correcting.
Old May 29, 2010 | 08:01 PM
miacycles's Avatar
miacycles
Make sure that nothing like the exhaust is touching the frame, floorboards or pegs as that will give you lots of vibration. Did it vibrate before the mount change??
Old May 30, 2010 | 01:25 AM
hatchetman's Avatar
hatchetman
Take a quick look at your tranny drive pulley as well. Make sure it has no movement on the shaft!
Old May 30, 2010 | 06:20 AM
grbrown's Avatar
grbrown
The swingarm is mounted on the back of the transmission, as also is the rear wheel. The engine/transmission/wheel assembly can be aligned within the frame, relative to the front wheel, by using the two adjustable stabilizer links (front and top of engine). By replacing the front or rear engine mounting rubbers there is a risk of disturbing that alignment.
If you don't have one get yourself a factory workshop manual, which explains both vehicle and wheel alignment (they are not the same thing!).
