Stator replacement question
Old May 30, 2010 | 08:32 PM
mjunk1's Avatar
mjunk1
Default Stator replacement question
WEll, I dug into the bike this weekend and found exactly what I thought - the cheap stator I bought had fried. Half of it was black as coal and stuff was melted all over the place. The other half looked almost new.
Anyway, enough of buying cheap parts. I did order an Accel replacement - mostly because I have always found their parts to be top quality and they have served me well. So I actually sat here pondering it and decided i was going to be brand loyal and hope that my personal integrity would pay off in the big karma picture - fingers crossed.
When I was pulling off the front gear, I noticed that the cup that covers the gear had 4 indentions in it. Three of the indentions look like they were punched into it to keep and interior part in place, but the fourth one is a bit suspect. Not sure if I somehow did it (I really don't think so) or if it is factory. It doesn't really do anything to the cup - it still fits nicely and all. But I am wondering if it is normal or if someone messed it up trying to hold the gear while they loosened that big old bolt. Any thoughts?
Old May 30, 2010 | 08:46 PM
RidemyEVO's Avatar
RidemyEVO
Replaced my stator this spring and it was the same way. I put an accel in mine as well and grommet was super tight fit and had to give it a smear of oil.
Old May 31, 2010 | 11:46 AM
t150vej's Avatar
t150vej
Dan, it's hard to say what's up with that without a pic, but that cup is the compensator spring pack or "washer" as the manual calls it. It has heavy spring steel beveled washers inside and the crimps simply hold it all together. Not recommended though I do all the time, if you re-use the stator bolts, clean them good and use medium (blue) Loctite and on the compensator nut also.
Old May 31, 2010 | 04:47 PM
mjunk1's Avatar
mjunk1
Thanks guys. I think it is factory like that as I really don't see how it could have gotten bent in without a serious whack from a hammer - no real noticable mark on the whack-side - or some kind of press which makes no sense at all.
I'll use the loctite for sure. Hope to be riding again this weekend.
Rufus, are you coming down to Hog Happening in Lincolnton?
chopchopchopitup401
EVO
Aug 21, 2025 11:14 AM
tonemachine
Electrical/Lighting/Alarm
Sep 1, 2015 03:59 PM
thewoozel666
EVO
Jul 28, 2015 01:27 AM
rpmpit
Jun 14, 2013 07:14 AM
hdwide04
Mar 19, 2009 03:29 PM
