Where does this go?
Old Jul 4, 2010 | 11:21 AM
Hogjob's Avatar
Hogjob
Default Where does this go?
Hi,
Can anybody identify this part? Its off a 90 Electraglide that I'm rebuilding.
I thought I'd labelled everything but no.
Help greatfully received
Paul
Old Jul 4, 2010 | 11:32 AM
Buddy WMC's Avatar
Buddy WMC
Yup,
That's the locking plate for your cam. It goes against the case and there should also be some shim(s). between that plate and the cam itself. A search here will tell you how to set the cam end play and gear lash up correctly.
Old Jul 4, 2010 | 11:57 AM
Hogjob's Avatar
Hogjob
Wow
How fast was that............ thanks.
Paul
Old Jul 5, 2010 | 10:43 PM
shovhd's Avatar
shovhd
If you don't have a parts manual you can check out this website. Lot's of good pictures.
http://www.bikebandit.com/1990-harle...-flhtc/o/m1142
Hope this helps.
Nigel
Old Jul 6, 2010 | 09:44 AM
Hogjob's Avatar
Hogjob
Thanks for the info
I have a manual, the problem is I stripped the whole bike, down to the frame, to rebuild it. I did take photo's as I went.
I came to put the rear caliper on this weekend, and there is that washer in with the rear brake/axle parts.
How it got there I don't know.
Still at least I didn't just throw it away, and...... its the only part I've left out (I hope).
Cheers
Paul
Sandcrab
Oct 1, 2020 11:32 AM
46u
Engine Mechanical Topics
Jun 5, 2013 10:01 AM
jjkuhnjr
Exhaust System Topics
Feb 22, 2009 07:44 AM
JimTJr
Oct 19, 2007 10:47 AM
dawg
Oct 10, 2006 06:33 PM
