replacement engine options?
My 107 dynoed at 102HP/103TQ and has a very flat torque curve, with over 90TQ from around 2,500rpm to over 5,500rpm.
Tell him about everything else you've done to update your bike, so he has the complete picture!!
http://www.sscycle.com/product/cart....detail&p=21080
And Baker 6 speed OD transmission gears.
that will make my old bike faster and more comfortable for long distance trips.
But Ihave no idea what primary to use! Or I can use stock one? Is not it too weak for new engine and trans? And again - I`ve heard with S&S engines motorcycle became more rough and noisy, what about rubber mounts - will they handle 111 S&S?
If you fit an OD transmission you will reduce the torque of your new engine to near stock levels when in sixth, which means you will see no improvement in performance, except by changing down a gear.
To explain that, if you have a stock bike with around 80 ft.lbs torque, compare that with my 107, which gives 103 ft.lbs. An OD transmission in sixth has a .86 ratio which reduces torque by that amount, to 88 ft.lbs. That ain't enough over a stock motor to be noticable!
A 111 will give a few more ft.lbs. torque than my 107, but to get the benefit of a new engine leave the transmission and gearing alone. Otherwise you will just kill it! If you want increased performance and an OD transmission, you need to get a radically larger and more powerful motor IMHO.
What I am saying is that if you fit an OD transmission, when in sixth gear your 111 will have similar performance to your stock motor in fifth. To some owners that will be OK, but when rolling on the throttle on the highway you will have spent a lot of dollars for no significant improvement in performance.
Put another way, a 111 engine will give a roughly 25% increase in torque over stock. An OD transmission will reduce torque in top gear by 16%. The difference on the road will not be very much at the seat of your pants. If you stay with your stock gearing, you will get the full 25% increased performance, at no extra cost!
To fit an OD transmission AND get a significant increase in performance will require a much bigger motor than a 111. It makes no sense to me to buy a big motor like a 111, then kill its potential performance gain by raising the gearing.
I live in the UK and bought my 1990 bike new. At that time we had more severe noise limitations than you in the USA and by bike had a 61T stock rear pulley. Since I installed my 107 and as part of my 'performance improvement programme' I fitted a 70T rear pulley, so my bike now has what was stock US gearing back in 1990. I have roughly 25% increased torque from my 107 AND 15% improved torque from the change in gearing, giving me almost 50% improved performance over a stock bike.
1. noise. We have some "nosie limitations" here in russia, bu nobody cares. So I do not care also.
2. Yes my torque at rear wheel will be reduced by 6 speed OD, but I will have same speed (80 mph is common between the cities) at lower RPM. isn`t it? So that is the idea. What I`m careing about is the more torque between engine and trans.
So you are sayng its much better to keep stock trans and change the motor. In my opinion what I will have in that case - more dynamics and that is all. I will keep 3 700 RPM for 80 mph.
P.S. New Idea - me, my girlfriend and my old flhtc at Bedford drinking IPA with you!
Twinkie riders make this 2 teeth drop on the trans pulley to make 6th more useable and complain about 6th being unusable, they have big factory cubes and talk about 6th lugging and won't pull out of it.
Bakers DD6 offers a 1 tooth less trans pulley for more giddy up other than the pulley that comes with it so dropping some teeth is in his playbook also.
2. You are quite right. If you use an OD transmission your 3,700 rpm will be reduced to around 3,200 at 80mph.
3. Buddy mentions Baker's DD6. If you read Baker's website they recommend using that instead of the OD6 and I have read other reports recommending that for a dresser. By using slightly lower overall gearing as 1997bagger suggests (cheaper to fit a smaller compensator sprocket on the crankshaft) you get a better first gear and also a higher top gear, although not as high as I mention at 2 above, about 3,500rpm at 80mph. If I fitted a 6-speed that is the option I would choose.
4. But it is cheaper to stay with your stock 5-speed. You could always fit a 6-speed transmission later!
5. If you have to pay import taxes (like I do here in the UK) it is a good idea to take expensive projects like these in easy stages, to keep the costs down, unless you can afford to do everything you want to in one big hit. A new motor is a big expense!
P.S. That's a great idea! One heck of a trip though! It's about 2,000miles (over 3,000km) one way. My wife and I travelled to Poland and back in May, just over 2,500 miles in all. My sig pic is of our bike resting in France, on the way back. You can see what wet weather we had!
