replacement engine options?
Old Aug 14, 2010 | 09:35 PM
97hawg's Avatar
97hawg
4th Gear
Default replacement engine options?
With all these cheap replacements like Revtech,Ultima ,etc.... I am thinking.... But do any of them have a crank sensor hole? I am kinda partial to my fuel injection... (S&S VFI) 97 flhtci
Old Aug 14, 2010 | 10:40 PM
1987fxr's Avatar
1987fxr
i dont know man but i had a gen1 revtech 88 in my kenny boyce bike and it was amazing id go revtech in a heart beat again it made 90 horse and like 95ftlbs i beat the crap out of it i revlimitered it like a jap bike it would smoke 600 crotch rockets 0-100 and give my causins 1000 a run to 100 it was neck and neck with my buddies 107 s&s witch ill never buy his had 8000 all ready needed rebuild mine has 19k when i sold it and it still made 89.9rwhp and would rip the bike into a wheelie im a firm believer in rev techs
Old Aug 14, 2010 | 11:04 PM
1997bagger's Avatar
1997bagger
That is going to be a tough one, I know S&S is the only company that produces an Evo EFI crankshaft but do they offer the cranksensor hole in their case? They may be the only research source available. M ight have to 4 5/8 stroker your case to keep the EFI, mine (flywheel kit) took 3 weeks to get because they manufacture it per order.
Old Aug 15, 2010 | 08:29 PM
BK Meyers's Avatar
BK Meyers
Default evo
Jireh Cycles is running a sale on their Ultima El Bruto engines. You can find them on Ebay or directly thru their website. S&S is also running a sale on some of their engines (I am considering the V111 for my '96 Road King). While the S&S is a bit higher priced I like the 3-year warranty and the parts availability.
BK
Old Aug 15, 2010 | 08:38 PM
david christopher's Avatar
david christopher
you can put EFI on the Jims motors also
Old Aug 15, 2010 | 09:38 PM
1997bagger's Avatar
1997bagger
Jims discontinued their Evo EFI crank so they can't put together a Evo efi engine, Ultima doesn't offer a Evo EFI crank so they can't put together a Evo EFI engine. S&S is the only aftermarket engine manufacturer that offers a EVO EFI crankshaft.
Couldn't find any S&S small cubed EFI engines, just monsters
http://www.sscycle.com/product/cart....detail&p=20968
Old Aug 15, 2010 | 09:49 PM
FLYING's Avatar
FLYING
I have seen a lot of aftermarkets and have done o'hauls as well and if I was going to buy one the only way I would go is S&S ! The Quality is what is important to me and there quality is Great ! Along with that is Factory tech support & a great warranty too!
Remeber you get what you pay for!
Old Aug 16, 2010 | 03:59 AM
grbrown's Avatar
grbrown
Websites like this one tend to collect the dirty stories about after market engines! There is enough here about Ultimas going wrong to put me off buying one, but I live in the UK, where the only substantial support is for S&S. If I lived in sight of Ultima and could knock on their door I might think differently about them.
Prior to buying my S&S V107T (replaced by their V111) I had a JIMS 89 inch stroker crank and other tuning mods to my original motor. I never had that dynoed, but it was quite strong compared with my 107. If you currently have a stock motor I suggest buying a significantly larger one, such as a 107/111. That way you will feel you have spent your money well.
Old Aug 16, 2010 | 06:51 AM
Kudray's Avatar
Kudray
To grbrown
I have a feeling even 100" S&S is too strong for stock 1991 FLHTC frame and primary / transmission. Do you have 107" engine in stock frame?
Old Aug 16, 2010 | 07:40 AM
grbrown's Avatar
grbrown
Originally Posted by Kudray
To grbrown
Yes! Frame is unaltered. The only changes I made were to fit a Barnett clutch spring. The rest of the clutch is stock and original 1990. I replaced all the rubber mounts with latest spec, plus a new compensator and primary chain (they were showing signs of wear).
My 107 dynoed at 102HP/103TQ and has a very flat torque curve, with over 90TQ from around 2,500rpm to over 5,500rpm.
