cylinder head replacement question.
Old Nov 16, 2010 | 12:07 PM
hdvespa's Avatar
hdvespa
Default cylinder head replacement question.
In changing the heads, Do I need to also remove the cylinders and replace the base gaskets?
Old Nov 16, 2010 | 12:22 PM
Dr.Hess's Avatar
Dr.Hess
It Depends. Do you want to? Why are you replacing the heads? Just a performance upgrade? If you're careful, you can just R&R the head without disturbing the base gasket, but there is still a risk that it will leak afterwards. "The right way" is to put new rings in and hone the cylinders if you take them off.
Old Nov 16, 2010 | 12:41 PM
hdvespa's Avatar
hdvespa
Dr Hess,
I have an issue with the rear cylinder, a rear mounting bolt boss area for the rocker broke, we tried jb welding it but still have an issue with oil leak between head and rocker. I wanted to just replace the rear head.
Old Nov 16, 2010 | 12:44 PM
Mike T's Avatar
Mike T
Originally Posted by hdvespa
Dr Hess,
.Go back with Cometic gaskets.
Old Nov 16, 2010 | 05:05 PM
RidemyEVO's Avatar
RidemyEVO
If your going to through the steps to removing the heads you might as well pull the cylinders and deglaze the cylinders ( at very least ) and replace the base and head gaskets.
txphatboy
Engine Mechanical Topics
May 2, 2015 09:25 AM
raconteur99
Jul 16, 2014 06:56 AM
avnsteve
Nov 12, 2013 08:05 AM
cbaker1@farmersagent.com
Exhaust System Topics
11
Aug 31, 2010 08:39 AM
chalmers
Shovelhead
Aug 22, 2008 09:06 PM
