Finding Neutral ???
Old Jun 8, 2011 | 07:45 AM
pjb's Avatar
pjb
x10 for the clutch adjustment. adjust it right and you'll have no problems.
Old Jun 12, 2011 | 06:06 PM
WP50's Avatar
WP50
[quote=Tom84FXST;8423801 To correctly adjust it, you have to find the tight spot on the chain...most people skip this step.[/quote]
Ok Things have slowed down for me a bit. I kept remembering your post. I understand what you said. If you have time could you please elaborate on that procedure
Old Jun 12, 2011 | 06:49 PM
miacycles's Avatar
miacycles
+1 on the clutch and primary chain adjustment along with making sure that all the linkage is serviceable. Also make sure you have gear oil in the tranny. Besides lubricating and cooling the tranny the drag from the lube also slows the gears down when you pull the clutch in. If the lube is too thin then you have less drag and neutral can be hard to find. Hope this helps.
Old Jun 12, 2011 | 08:28 PM
shovhd's Avatar
shovhd
My bike shifted decent, went into neutral with a blip of the throttle and I thought that was normal......It is not!!! I thought I had a clue about adjusting a clutch, but after an old school wrench at Eagles Nest HD in Lathrop, CA adjusted it I realized I was just an amateur. No blip required and it goes into neutral with just a flick of the toe. I wish I knew what he did because it makes it a real pleasure to ride and it would suck having to travel 1000 miles to get it readjusted.
Old Jun 12, 2011 | 08:32 PM
customclimates's Avatar
customclimates
Originally Posted by the blob
i find that if im stoped in 1st gear, i just blip the throttle 1 or 2 time while applying slight pressure on the shifter it pops into neut. easy.
Agreed .... my road king always needed a little throttle to nudge it into neutral
Old Jun 13, 2011 | 01:23 AM
grbrown's Avatar
grbrown
A chain is an assembly of a great many small parts and the precise length of each link differs very slightly. So if you slowly rotate the primary (take the spark plugs out and rotate it via the rear wheel in top gear), you will probably find the chain is tighter in one spot than elsewhere around it. Check adjustment at that tight spot. If the chain is correctly adjusted, but at the slack part, there is a risk of the chain being very tight at the tight spot and putting a lot of strain on the bearings and seals. That is not good!
Hope that helps.
Old Jun 13, 2011 | 07:17 AM
WP50's Avatar
WP50
Originally Posted by grbrown
Hope that helps.
It does help Thank You very much WP
Old Jun 13, 2011 | 07:20 AM
WP50's Avatar
WP50
Originally Posted by customclimates
Agreed .... always needed a little throttle to nudge it into neutral
Thats a great way to say it. WP
Old Jun 13, 2011 | 07:25 AM
WP50's Avatar
WP50
I changed the tranny fluid to a syn gear oil. In draining it the fluid that was in it smelled like syn. I put Gm syn 75-90 gear oil. had a good bit of it laying around. Didn`t seem to change much in the shifting or getting neutral. Thanks for the help.
Old Jun 13, 2011 | 07:29 AM
WP50's Avatar
WP50
[quote=shovhd;8445244 but after an old school wrench at Eagles Nest HD in Lathrop, CA adjusted it I realized I was just an amateur. No blip required and it goes into neutral with just a flick of the toe. [/quote]
Mine is much like you describe, shifting ok but this neutral is tough. I got somethings to ck. Thanks WP
brucepancake
May 12, 2019 08:33 AM
DMWyant
Sep 5, 2015 10:58 AM
gavdar
Sep 1, 2012 04:22 AM
johnnyholmes
Apr 26, 2010 09:09 PM
wolf1477
Ironhead
Jan 16, 2007 04:23 AM
