1985 evo primary
Old Jul 10, 2011 | 02:53 PM
dmh's Avatar
dmh
6th Gear
Default 1985 evo primary
i have a 1985 flh evo and idk where to fill the oil level to in the primary or how much oil it holds. i just bought it and now the clutch isnt acting right
Old Jul 10, 2011 | 03:06 PM
Bama91's Avatar
Bama91
28 ounces or with bike standing level (not on kickstand) open the clutch cover and add until the fluid is about 1/2-1 inch up the clutch pressure plate. This will be close to over running and spliiling out. (28-32 oz.)
Old Jul 10, 2011 | 03:09 PM
Bama91's Avatar
Bama91
Also, run type F ATF fluid, a lot of people on here have told me it's betterthan the expensive fluids.
Old Jul 10, 2011 | 03:13 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
With the bike standing up level, fill it until the oil just touches the outer diameter of the diaphragm spring. Any more than that and you will have clutch problems, especially finding neutral.
Old Jul 10, 2011 | 03:35 PM
Bama91's Avatar
Bama91
You worded that better. The fluid is primarily to lube the chain, not to soak down the plates.
Old Jul 10, 2011 | 03:49 PM
Uncle G.'s Avatar
Uncle G.
What Dan said, go by level, not by capacity.
MadMonkMort
Shovelhead
Mar 27, 2019 06:02 PM
91fxrslowrider
EVO
27
Feb 18, 2016 11:25 AM
Gilmb
Oil Archive (no new posts)
Feb 11, 2015 08:40 PM
Sibs
Custom Models
Jun 13, 2011 08:41 PM
jube455
13
Apr 24, 2006 09:00 AM
