Engine ID problem
Old Sep 2, 2011 | 11:02 AM
Bama91's Avatar
Bama91
Default Engine ID problem
I bought an Inner primary, clutch pack for my bike (you older members remember my problems). Won't fit! When I line it up on the transmission I have a 1/2" gap between the inner primary and the engine. Plus only 1/2" of transmission shaft showing. PO told me it was a 1988 FXR motor and tranny. Had an E84 clutch and primary on it. So I went and checked engine ID number. After much searching there is no number on the left case. There is a number on the right outer case front. 7000 310 17. These do not match any of Harley's numbers. The jugs do have a Harley ID number on them, listing them as Harley-Davidson 1340 CC jugs. it is a rubber mount motor and a harley 5spd tranny. Any help? I cannot locate this nuber.
Old Sep 2, 2011 | 02:34 PM
Bama91's Avatar
Bama91
Between the jugs on the left side reads NITRALLOY if that helps.
Old Sep 2, 2011 | 03:04 PM
Bama91's Avatar
Bama91
Just got off the phone with HD in Milwaukkee Wis. Not a HD block. So I'm stuck. Have no Idea the Year model or who makes it. Every thing else is HD.
Old Sep 2, 2011 | 03:19 PM
smitty901's Avatar
smitty901
Find an indy shop that has been around awhile.
There will be someone around 50 years old that will know what you have. It was common to mix after maket parts with HD EVO parts
Old Sep 2, 2011 | 04:32 PM
Bama91's Avatar
Bama91
Seems to be an aftermarket block. Is there an id on the tranny?
Old Sep 2, 2011 | 04:45 PM
Tom84FXST's Avatar
Tom84FXST
Evo cases are all the same... on how they bolt up to the primary...the primary just needs to match the trans/frame set-up. Post some pics of the primary, and someone will help you out
Old Sep 2, 2011 | 08:15 PM
miacycles's Avatar
miacycles
Hey Bama, how about some photo's of the pieces?? Remember a picture is worth a thousand words!!!
Old Sep 2, 2011 | 08:28 PM
miacycles's Avatar
miacycles
Bama, Nitralloy cases were made by Sputhe, They were available in different sizes, stock to very large bore. If you contact them with those numbers perhaps they could tell you more. How about some pictures of the other problem, remember a picture is worth a thousand words.
charlesrt88
Shovelhead
Sep 13, 2015 10:30 PM
Bubba12
Dec 30, 2014 01:32 PM
D1gger
EVO
62
May 23, 2012 05:33 PM
hdpeanut1
Mar 17, 2011 10:28 PM
McGillicutty
Exhaust System Topics
Oct 30, 2006 06:00 PM
