95 fxd
Old Oct 5, 2011 | 08:50 AM
jsa750k's Avatar
jsa750k
5th Gear
Default 95 fxd
It had been having problems not keeping a charge,kept getting "click" after only a short time.Replaced the 5 yr. old battery. Perfect,except after a 3 mile ride,"click" again. Do all elec. tests,not getting charging voltage when running,only 11 v across terminals.Re-charge battery, I even took out stater and did bench tests,it passed,I re-install it and it starts right up. Cool,now I'll just get a reg/rec and be good. Install new reg/rec and button it all back up and " click,click,click" . WTF Help please.
Old Oct 5, 2011 | 09:00 AM
grbrown's Avatar
grbrown
There are lots of threads about this problem. Enter 'starter click' in 'Search this Forum' and you will find plenty of suggestions to help you through this.
Old Oct 5, 2011 | 03:02 PM
stokes's Avatar
stokes
Check the negative connection at the battery,Sometimes it seems to be okay but a half turn makes a difference.
Old Oct 6, 2011 | 06:58 PM
jsa750k's Avatar
jsa750k
5th Gear
Default 95 fxd
Think its possible for the starter and solenoid to pass all the bench tests,then when it re-installed,clicks again ? I removed the starter,I took the solenoid apart and cleaned the contacts and cleaned up all the connections. I installed it all and it started right up! Ran for 5 mins then popped a breaker. The key switch was bad. So, I replaced it,and it clicks all over again. I just wonder with the starter being under load,is it just too tired to turn the engine over ? I did continuity checks on all the connectors,and voltage drop tests as per manual flow chart and it failed for the battery connection. The battery connection post turns just a fuzz when I loosen the nut. Hmmmmmm
Doc2nd2
Electrical/Lighting/Alarm
May 31, 2015 06:01 AM
Maddogs700srx
Jun 6, 2013 03:27 PM
texashillcountry
EVO
36
Mar 21, 2012 09:55 PM
Burzum
Jul 16, 2009 10:30 PM
superglazier
Jun 9, 2007 12:19 PM
