Part numbers help
Old Nov 26, 2011 | 11:27 PM
RidemyEVO's Avatar
RidemyEVO
Default Part numbers help
Hi guys I'm looking for the oem part numbers for the flht probably EVO to 2007 would be similar but the part numbers I need are for the muffler mount ( 2 bolts on top of end of muffler right to the hanger. I know there's the
Rubber square piece and the 2 bolts that go into the top of the muffler but not sure on the rest of the hanger assembly but could use all the numbers if someone has a parts book. I just got an 06 touring exhaust with python mufflers but my exhaust fishtails with the round clamp.
Thanks
Old Nov 27, 2011 | 03:23 AM
grbrown's Avatar
grbrown
Hi Lynn,
Mount, rubber is #65724-85,
Mounting bracket (goes through the rubber) is #65723-85,
Bolt 4 off is #3953W (5/16" 24tpi 1/2" long),
Lockwasher 4 off is #7041.
Howzat?!
They are from my 1987-90 parts book.
Old Nov 27, 2011 | 04:58 AM
RidemyEVO's Avatar
RidemyEVO
Thanks Graham very much appreciated.
All I need now is the part number for the part that goes from the frame where ever that goes from to the rubber and metal piece that is held on by two bolts, I guess it would be some sort of hanger.
Old Nov 27, 2011 | 07:21 AM
grbrown's Avatar
grbrown
Lynn,
Together we can do this! I assumed you mean your Glide? in which case the rubber fits in a recess under the short part of each saddlebag support, the tubes that run from each side of the rear fender to the rear guards.
Old Nov 27, 2011 | 10:28 AM
RidemyEVO's Avatar
RidemyEVO
Yes Graham thats the one.
Old Nov 27, 2011 | 03:24 PM
grbrown's Avatar
grbrown
Support saddlebag right is #90781-85,
ditto left is #49194-85.
Old Nov 27, 2011 | 07:58 PM
RidemyEVO's Avatar
RidemyEVO
Thanks Graham, after a closer look on my bike it would seem I do have all the correct parts and the extention for the fishtails was just added on in one of the two bolt holes.I think I better replace the rubbers though.
Old Nov 28, 2011 | 01:25 AM
grbrown's Avatar
grbrown
Lynn, they look the same as mine!
Old Nov 28, 2011 | 09:32 AM
RidemyEVO's Avatar
RidemyEVO
I'm thinking they probably are. When I pulled the old exhaust off I had a spare moment to try the new header from the 2006 and it seems to fit snugger into the head as well as it lines right up with the half moon shape on the bracket of the hear box, it also seems to be aiming higher along the bike so when I get a chance to try the muffer I expect it to be higher and line right up with the mount.
Old Nov 28, 2011 | 11:02 AM
grbrown's Avatar
grbrown
I have a 2008 SuperTrapp system on my 1990 and that fits fine, as you can see below!
