Bad coil?
Old Dec 29, 2011 | 05:35 AM
FXD_One's Avatar
FXD_One
I just bought my first Harley, a carbed Dyna and had troubles starting it. I figured out if I pull on the choke give the throttle a good couple of turns it fires up every time. Seems it wasn't getting enough fuel after sitting even over night.
Anyone else have this problem or is there something I should be fixing? lol
Old Dec 29, 2011 | 06:47 AM
Dr.Hess's Avatar
Dr.Hess
Originally Posted by kcoughenour
I just bought the bike less than a month ago, so dont know much about it other than Screaming Eagle heads, S&S Carb and breather, DynaTech ignition module and coil.
I had a hard time getting it started from the get go. I suspect some of it was getting use to the choke, but I also changed the plugs and it ran like a champ. Then sunday, I rode about 100 miles, ran great all day until I was just about home, then it sputtered and died... havent been able to start it since. I havent changed anything at all on it.
Well Im obviously gonna have to do some more troubleshooting in the areas you mentioned. Thanks for the info!
You have a carb/fuel issue. What color are the plugs?
Start with a clean set of plugs (again). You can use the cheapest champions here until you get this all figured out. That is, you don't have to buy "super $creaming Eagle" branded whatever plugs. Were the old plugs wet? See if it starts. If not, spray a little starting fluid around the back of the intake (I assume you have the S&S air cleaner as well,) and crank it. If you have the vacuum operated petcock, a vacuum leak will shut off your motor. Most people replace those things. Pingle makes a good one.
Old Dec 29, 2011 | 08:03 AM
soft 02's Avatar
soft 02
An alternitave to spraying starting fluid around your intake is to use a small propane torch and fog around the intake. less messy and less dangerous.
Old Dec 29, 2011 | 01:05 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
+1
Also what color are the plugs you are pulling out? White means it is running lean and black means rich. What you want is a light brown.
Old Dec 29, 2011 | 01:52 PM
TwiZted Biker's Avatar
TwiZted Biker
Seen a guy blow the head off a bike with a propane torch and few eyebrows cooked off , use non chlorinated Brake clean the engine dies out not takes off . Much simpler for the non mechanically inclined .
Old Dec 29, 2011 | 01:56 PM
soft 02's Avatar
soft 02
WOW. My bad. Thats what Ive always used since i Caught my hands on fire with carb cleaner many years ago.
Old Dec 29, 2011 | 02:04 PM
TwiZted Biker
Carb cleaner no **** you did , brake clean is whole different animal the non chlorinated stuff non flammable California special one of the few things they go right .
Old Dec 29, 2011 | 02:38 PM
soft 02's Avatar
soft 02
Yea not a fan of the CA brake clean. Basically acetone in a can (well the stuff I get at Napa is) and if your not carefull it will remove paint off a motor. At least it removed some of the silver paint off my motor.
Old Dec 29, 2011 | 02:40 PM
Dr.Hess's Avatar
Dr.Hess
Actually, we weren't looking for a manifold vacuum leak in this case, but looking to see if he has no fuel. A little starting fluid squirted at the opening for the air cleaner (behind the oval on a S&S,) and if it tries to fire, indicates he has no gas. Thus, I suggested a quirt of starting fluid. A non-flammable fluid wouldn't help him start at all.
Old Dec 29, 2011 | 02:43 PM
TwiZted Biker
Skip napa , I get mine in bulk from Walmart or harbour frieght way cheaper . Yes you do have to pick and choose where & how to use the stuff , LOL .
