help with clutch
well here i go again with clutch questions.
i have a 95 flhtcu with a built motor and stock trans clutch
can i replace the clutch assembly with a later model that uses the six bolt for the spring. i have an oppertunity to buy a complete primay setup out of a 05 rk with low miles just want to make sure it will work in my bike
Yes you can. it will bolt in fine. it uses the same clutch push rod, lock nut and adjusting screw. the only difference is that the primary chain drive gear has 36 teeth where yours has 37. ( I believe thats the right numbers, been awhile since I counted) the net result is that you cruise in 5th gear at a couple hundred rpm lower.
Velocity1
Jul 28, 2013 08:35 AM
