clutch isses?
Old Nov 6, 2011 | 05:52 PM
cobrahd1999's Avatar
cobrahd1999
Default clutch isses?
I followed the book yet when I pull the clutch leaver in its not disengaging and the bike is still in gear yes I am doing all this on my jack and a cold bike.
I am just stumped.
thanks for any help
Old Nov 6, 2011 | 06:09 PM
PanHeadRich's Avatar
PanHeadRich
I am just stumped.
thanks for any help
It could be difficult to determine whether the clutch is or isn't disengaged while the back tire is off the ground. If you're trying to rotate the tire by hand while holding the clutch lever in, while the bikes in gear, there will be quite a bit of drag on the clutch plates, possibly making them feel like they're still engaged. I'd drop it to the ground and feel it out.
Did you ever leave your bike in gear with the engine off, hold the clutch in and push the bike? you'll feel the clutch drag I'm talking about.
Just a thought...
Old Nov 6, 2011 | 06:23 PM
JohnnyC's Avatar
JohnnyC
What year are you working?
Did you adjust the mechanical adjustments (slotted bolt and locking nut) on the clutch, for the push-rod adjustment first?
Old Nov 6, 2011 | 06:36 PM
cobrahd1999
Just a thought...
Thanks PanHeadRich I will drop it to the ground and see what happens. I didn't even think of that da. That's what it could be.. Yr 99 Evo
Old Nov 6, 2011 | 07:24 PM
cobrahd1999
Thanks that's all it was. Tomorrow I will take it for a ride and see how everything is. I put Redline the tranny so I think that will help it seems to shift better just testing it in the garage.
Again a big thanks..
Old Nov 6, 2011 | 08:07 PM
PanHeadRich
Good deal
Old Nov 7, 2011 | 05:58 AM
Rodzilla6's Avatar
Rodzilla6
Just a thought, not saying it is a problem...I was running Redline in my tranny and liked it, BUT one of the folks on the forum had a tranny failure and their were CHUNKS of the suspended particles jammed in the bearings...I then went and checked my Redline bottle I was going to use to change mine and found that it has NO CERTIFICATION NUMBERS at all. I think we are supposed to use a G4 or G5 RATED tranny fluid?? Did not make me feel comfortble leaving it in and had it changed out. Not worth the risk to my tranny IMO...Ride safe!
D-BOY
Nov 7, 2014 03:08 PM
cchenf50
May 30, 2013 01:55 AM
btroy
EVO
Oct 31, 2008 07:41 AM
bobbsterkid7
Aug 2, 2007 02:01 PM
panshovel
Jun 15, 2007 12:11 PM
