Clutch issue when starting
Old May 30, 2013 | 12:37 AM
cchenf50's Avatar
cchenf50
Exclamation Clutch issue when starting
Just recently put some apes on my 09 SG. After they were installed, I followed the service manual on how to adjust the clutch and everything but when I go to start the bike in gear (of course with the clutch lever pulled) the bike wants to lunge forward. If the bike is not running and in gear it is hard to push it when the clutch is depressed. can anybody point me in the right direction?
Old May 30, 2013 | 12:42 AM
mkguitar's Avatar
mkguitar
it is normal that when you hit the starter, there is some forward movement- just from the clutch plates stuck together.
they should "free-up" right away
that's with a properly adjusted clutch.
I am thinking though that you need to go over your adjustment again.
lots of threads on adjusting
the motorcyle clutch is a multiplate design, not like a car clutch where when you push the pedal all the parts are pulled apart fron each other.
On the bike clutch there is always a little '"stiction" causing the plates and disks to stay in contact for a moment
on old British bikes with a wet clutch, a couple of kicks were to free up the clutch
Mike
Old May 30, 2013 | 01:17 AM
cchenf50's Avatar
cchenf50
after the bike warms up a bit, i have no issue pushing it with the clutch depressed. normal?
Old May 30, 2013 | 01:55 AM
mkguitar's Avatar
mkguitar
probably- it's a judgement call- a matter of degree
when you start the bike in gear, clutch pulled, it will jerk forward a bit...but it won't shoot into the laundry room.
neutral is good for starting
Mike
mgmmgm
Dec 23, 2023 10:38 AM
ejs262
Jul 15, 2015 06:10 PM
heavymetalthunder
2014-2024 Touring Models
53
May 15, 2015 11:34 AM
Joshua
Apr 11, 2010 03:01 PM
BOARGAURD
Feb 2, 2007 10:28 PM
