Ignition Problem
Old Jun 17, 2012 | 10:36 AM
okidiver2001's Avatar
okidiver2001
Default Ignition Problem
I have a 94 EVO that I just started having a problem with. The front cylinder is misfiring when it's first started and then it settels out and rund great with it's warm. It's only the fron cylinder and only cold. I've switched the plug wires around, put new plugs in, put new wires on, and NOTHING changed this. It's always the front cylinder. Any ideas????
Old Jun 17, 2012 | 12:15 PM
Dr.Hess's Avatar
Dr.Hess
Burnt exhaust valve?
Is the front plug significantly darker in color than the rear? Is it wet with gas or oil? Check the compression when it is cold and when it is warm. Leak down test when cold. Just tossing out ideas.
Old Jun 17, 2012 | 12:55 PM
okidiver2001
Thanks Dr. Hess,
I'm not too sure that's it. And this is why I think that. I just had the motor apart and put 10.5:1 Kieth Black pistons in. and tested the compression. It's steady and strong at 175psi.
I also forgot to mention that I tested the spark using my timing light. On the back cylinder it's steady. The front cylinder is not. So I'm thinking it's an electrical problem
Old Jun 17, 2012 | 01:06 PM
miacycles's Avatar
miacycles
What type of ighition do you have???
If you have an after market, perhaps the trigger wire to the front coil is loose or has an intermitent connection or the coil is going bad on that side.
John
Old Jun 17, 2012 | 01:11 PM
soft 02's Avatar
soft 02
John
Sounds most plausible. Although id do the comp tests. To confirm weak coil id swap the input wires to the coil so the one for the front fires the rear and such. Eliminates the coil or confirms.
Old Jun 17, 2012 | 01:14 PM
okidiver2001
As far as I know the ignition is stock, but i do have the Screaming Eagle module under the seat. I was thinking the coil might be going bad but didn't know if it would effect both cylinders...
Old Jun 17, 2012 | 01:16 PM
okidiver2001
I will do that. and see what happens thanks.
Old Jun 17, 2012 | 02:38 PM
miacycles's Avatar
miacycles
OP stated he already switched wires around and replaced them. Compression/leakdown test is a good idea too.
John
Old Jun 17, 2012 | 02:41 PM
soft 02's Avatar
soft 02
John
He did the plug wires not the imput wires to the coil. He only confirmed the plug wires are good not the coil to the front cyl.
Old Jun 17, 2012 | 04:13 PM
miacycles's Avatar
miacycles
Screaming Eagle ignition module fires both cylinders at the same time. So either no/low compression or bad coil. The pick up could be going but this is very rare when it starts on one side first, but it can happen.
John
