fxr's
Old Jan 25, 2007 | 10:01 PM
lowglide's Avatar
lowglide
Default fxr's
anybody know how many fxrs's were made in early 1984..... evo engine 5 speed trans............ or know where i might be able to get this info from????? also how would you find out what # bike it is in the production run...... any info would be great ..... thanks in advance !
Old Jan 25, 2007 | 11:03 PM
RudeDog's Avatar
RudeDog
Default RE: fxr's
Your local dealer will be able to give you a number as to hoew many were built that year, they have access to all sorts of information. The production number of your bike is in the VIN's last digits, i.e. if you've got VIN #1HD1ELK12BZ123456, the "123456" is the production number.
Hope this answers all your questions. Have a great day!
Old Jan 29, 2007 | 08:11 PM
Sandhog's Avatar
Sandhog
Default RE: fxr's
OK heres the deal with the FXR's
1079 Shovelhead FXRS's were built
1731 Evolution FXRS's were built
834 Shovelhead FXRT's were built
1196 Evolution FXRT's were built
also there were limited edition FXRDG'sand FXRSDG's that were built and thought to have all been Evo models BUT it cant be confirmed.I always thought the FXRDG andFXRSDG didnt come out till 1985 but the info proves that wrong.
I have an 84 FXRPand Im not sure if they were included in those numbers or not.
There are quite a few people who really follow the FXR series,and have posted quite a bit of info about them on the web.
One great place is http://www.nightrider.com/
There are a few people on that site that hot rod FXRs and can pretty much tell ya all ya need to know OR can steer ya in the right direction to find what ya want.
Good luck
Old Jan 30, 2007 | 02:20 PM
89FLHT's Avatar
89FLHT
Default RE: fxr's
Don't know the numbers... But I had a early 1984 FXR for almost 12 years. 1st of the EVO/5speeds/chain drivewith the old shovel 3 stud clutch. Besides having to upgrade the clutch to handel all the engine work I did to it, the bike was flast out awesome.
Old Feb 2, 2007 | 11:19 AM
lowglide's Avatar
lowglide
Default RE: fxr's
that what i have early 84 evo with 3 stud clutch , would like to only change the front end to a wide glide,,, is that hard to do??? do i need new front wheel then? bike runs like raped ape!!!
Old Feb 2, 2007 | 11:20 AM
lowglide's Avatar
lowglide
Default RE: fxr's
thanks for the info sandhog!
Old Feb 2, 2007 | 02:31 PM
mp's Avatar
mp
Default RE: fxr's
You can get most any front end you want. You can get wider trees to spread out the forks you have- although yours are 35mm so I wouldn't do that. I'd get something like the 49mm fronts on the new Dynas. Those are the cat's a$$.
Old Feb 2, 2007 | 03:48 PM
lowglide's Avatar
lowglide
Default RE: fxr's
i really like them too, but would'nt i have to get a new front wheel and brake caliper and disc rotor?? hmmm headlight too..... what do you do with all the wiring thats inside the current headlight( where does it go??)
Old Feb 2, 2007 | 05:54 PM
89FLHT's Avatar
89FLHT
Default RE: fxr's
Most all Mid Glide and Wide Glide conversion kits that include the Triple trees are for 39 mill fork tubes. Finding a conversion kit for 35 mill tubes like yours is hard to come by. The kits i've seenwill include the axles, spacers, rotor spacers,etc. to allow you to use your current wheel. If you can find a comlplete conversion kit it will utilize your existing forks so the brake caliper will remain.
For headlights, if you replace the stock eyebrow and bucket with a light from a wideglide, you will need to relocate alot of the connections from the headlight bucket to the frame (Like underneath the seat.)
Old Feb 2, 2007 | 06:34 PM
mp's Avatar
mp
Default RE: fxr's
Jireh has kits for your bike for $420. I would recommend a fork brace, but not sure if anyone makes a wide one in 35mm.
As an aside, the reason for the narrowglide forks on the FXR's is to improve handling. Are you sure you want to make the change?
