Reinstalling cylinders
Finally got my cylinders and heads back from the machine shop and ready to get her back together.
How did I manage to get them out so easy with the pistons still in the cylinders? Now that I've repainted them, I guess I'm being real careful. The rocker boxes were a bear to get off with the engine in the frame, but the cylinders were easier, I thought.
Any ideas?
Any ideas?
BTW, this is a recommendation from S&S and there is no doubt they know quite a bit about building engines.
No but you might have a bent stud and that is hanging things up.
I'm sure I don't have a bent stud, and I'm pretty sure the PO has never been in the engine this far.
It seems I'm in able to get it to the point where I line up the studs with the holes. I got them off though, so I think I may be being a little too ginger with it as I have just painted everything as well and don't want to scar them.
I'm about to head home for the day and give her another try. I guess putting the cylinders back on is like Tetris, only goes one way.
It might be too late but cleaning the inner cylinder liners with soap and water is a good thing to do to remove any debris within the cross-hatch. Any debris can prevent the rings from seating properly and can score up the piston skirt.
after the soap and water you MUST clean the linings with a white rag and some 10 weight or ATF oil... the soap won't get everything
keep wiping with the white rag and oil until there is no black residue left on rag
Finally got her. There was no way the rear cylinder can be installed with the piston in it together at the same time. I took the piston out, put it on the connecting rod, and then was able to get the cylinder in place.
The front jug and piston was able to be installed together.
When using cometic layered head gaskets, do I still need the o-ring that sit on the dowels per the manual(95 softail custom)? Cometic kit didn't come with them.
did you deck the pistons, too?
