Hard starting and poor running
This is on a 96 model Heritage Softail, the bike is acting as if the starter is draging a little for the first turn over, then it will start to spin real fast and start, the bike has 16,000 miles on it and they also put a new battery on it and it still does it, I know it could be the starter but the bike doesn't run all that well, it never has, also it seems as if it's starting to cut out a little while driving down the road, I guess my question is, can the pick up in the ign.can cause this problem, will it advance the time to much or cause the unit under the seat to go bad, we was just trying to come up with the right problem.
RE: Hard starting and poor running
Maybe, but that doesn't explain why the bike is shutting off like the swicth has been cut off for a second while driving down the rd,the bike has always been weak, after he bought it he put new coil, plug wire's, rejetted the carb and other things that the Harley shop told him to do and he said it made no difference at all in the way the bike performned.
ORIGINAL: pittguy
Could be ignition switch.
All the right things have been checked or replaced.Rejetting the carb was probably unnecessary unless the pipes have been changed.I would either take the carb off to clean or use some good carb cleaner...or put an S&S E on it.I wpold also check the battery connections ,If one is loose and loosing contact,it will do what you described.
ORIGINAL: Tn.Heritage...This is on a 96 model Heritage Softail, the bike is acting as if the starter is draging a little for the first turn over, then it will start to spin real fast and start, the bike has 16,000 miles on it and they also put a new battery on it and it still does it, I know it could be the starter..
ORIGINAL: Tn.Heritage...but the bike doesn't run all that well, it never has...
ORIGINAL: Tn.Heritage...also it seems as if it's starting to cut out a little while driving down the road, I guess my question is, can the pick up in the ign.can cause this problem, will it advance the time to much or cause the unit under the seat to go bad, we was just trying to come up with the right problem.
homedawg247
09-27-2006 12:05 AM
