starter problems again
Old Apr 4, 2013 | 04:02 PM
NickSchoff's Avatar
NickSchoff
Default starter problems again
im sure this has been covered at some point, but I need some options. I have a 99 heritage and I went to start her up today and the starter will not engage, now this starter is a year old last starter same problem. I've been told that this is commen problem. So im looking for a better solution, better or different starter whatever gets me down the road without changing starters every year.
Old Apr 4, 2013 | 04:47 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You burn out a starter every year?
First things first. What is the voltage at the green wire on the starter when you hit the start button?
Old Apr 4, 2013 | 04:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Exactly what is the problem?
There is almost no good reason to replace a starter. If you think the second starter has the same problem, you most likely are misdiagnosing the problem.
Old Apr 4, 2013 | 04:59 PM
texashillcountry
Dirt don't hurt
How long are you holding down the start button when you are starting your bike?
Old Apr 4, 2013 | 05:35 PM
Beemervet's Avatar
Beemervet
Starter clutch or low voltage.
Old Apr 5, 2013 | 06:12 AM
EVOrider's Avatar
EVOrider
My starter problem is similar on my Ultra....turn on the ignition and hit the starter button. The starter does not engage....sometimes it might click sound, but still will not start. So, I have to use the direct starter button on the starter itself.
Once the bike has been started and warmed up.....then the starter button on the handlebar works. Any ideas here too......
Old Apr 5, 2013 | 06:17 AM
texashillcountry
Dirt don't hurt
Again the first thing to check is the voltage at the green wire on your starter when the handle bar button is pushed.
Old Apr 5, 2013 | 06:29 AM
RidemyEVO's Avatar
RidemyEVO
Do an advanced search on "dreaded click" in the evo section.
Did the search for you https://www.hdforums.com/forum/evo-c...ded-click.html
Old Apr 5, 2013 | 08:26 AM
texashillcountry
Dirt don't hurt
Have to check the voltage at the green wire to make sure he is having the dreaded click problem.
garystaven88
Electrical/Lighting/Alarm
Oct 25, 2015 11:39 AM
Rabbito
Shovelhead
11
Jul 16, 2014 06:48 PM
ironhead1987
Jun 30, 2012 11:43 PM
cruiser66
Exhaust System Topics
Aug 9, 2010 12:33 PM
sunup420
EVO
Feb 7, 2010 11:58 AM
