compression test procedure question
Old Apr 16, 2013 | 11:20 PM
terrapin88's Avatar
terrapin88
Default compression test procedure question
I am getting ready to do my base gaskets and install a cam. I wanted to do a compression test before I pull things apart but oops, I've already sent off my carb for some work. The manual says warm engine and open throttle to test compression. Am I wasting my time to try and test with a cold engine missing the carb? I'm guessing the carb is needed if only to plug the intake manifold?
I am also guessing you will have different pressure reading between a hot and a cold motor.
BTW, Autozone lets you borrow a compression tester with a $42 deposit. As long as you return the tool within a year you get you $42 back. Not a bad deal.
Old Apr 17, 2013 | 12:04 AM
3408pete's Avatar
3408pete
where you are going with this engine I would say a leakdown test would be in order myself
Old Apr 17, 2013 | 12:15 AM
Spanners39's Avatar
Spanners39
You can do the compression test as it is now but the results will be a bit skewed....however, if one pot is stuffed it will show up on the test as the differences between the pots will still show with a cold motor.
My outboard motor shows lower comp when cold than when hot. I use it as an example because I just checked them hot and cold at the weekend.
Old Apr 17, 2013 | 10:30 AM
terrapin88's Avatar
terrapin88
Thanks for the replies. I am going to do a leakdown too. I just need to grab the kit. I'll do the compression test just to see if both jugs are the same or similar. Would blocking off the open intake manifold do any good?
Old Apr 17, 2013 | 01:35 PM
Spanners39's Avatar
Spanners39
No, you do the test at wide open throttle, so leaving it open is good :-)
Old Apr 17, 2013 | 01:57 PM
terrapin88's Avatar
terrapin88
Duly noted. Thanks Spanners39
Old Apr 17, 2013 | 03:18 PM
3408pete's Avatar
3408pete
the difference from hot to cold is basically negated un scientifically if you shoot a little engine oil in the bore before the tests.that will mimic a hot run condition
Old Apr 17, 2013 | 08:01 PM
machinehed's Avatar
machinehed
Default test
Firstly you need to know what exactely you need to know and what procedure
is appropriate and correct.
You can purchase a good screw in compression gauge at any auto supply store for $ 30.00 - $50.00 then follow the instructions included.
Old Apr 19, 2013 | 06:21 AM
junglejoe's Avatar
junglejoe
I just did this on my bike befor i tore it down....cold and hot and the added oil.It gained 10 psi when warm and absolutly nothing when i added the oil accept smoked like a freight train when i started it...LOL
Old Apr 19, 2013 | 09:38 AM
terrapin88's Avatar
terrapin88
cool thanks for the info junglejoe.
