SE11 cam
Old Sep 9, 2013 | 03:53 AM
Spanners39's Avatar
Spanners39
Default SE11 cam
You hear a lot about ev27 cams but there is an se11 available down our way and Kees was asking me about it but I have never fitted one. How do they compare to the ev27?
Old Sep 9, 2013 | 06:29 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It's been a while but last I heard the SE 3 was about the same as the EV 27.
I don't know about the SE 11.
Old Sep 9, 2013 | 06:48 AM
Kushman's Avatar
Kushman
Here you go, it's for lighter bikes
This is the next generation SE-1 bolt-in cam for lighter bikes. Advanced profile design, creates power from 3500-6000 RPM. This is an awesome horsepower cam in a bolt-in disguise. Unless specified, not for use on EFI models.For Race Application Only!
Note: 1340 Cams over .510” lift may require case and/or tappet guide machining for cam lobe clearance. 84-85 model’s pistons may need to be fly-cut to obtain proper clearance. Please refer to instruction sheets and service manuals for more details.
* Warning Harley’s® equipped with some Screamin’ Eagle® High Performance engine parts may not be used on public roads and in some cases must be restricted to closed course competition. Engine Related Performance Parts are Intended For Experienced Riders Only!
Warranty Implications: Installation of these products (and similar products from other manufacturers) may void your Harley-Davidson® Limited Vehicle Warranty.
Click icon for more information
Specifications:
Lift @ valve Intake/ Exhaust.508”/.508”)
Duration @ .053 Intake/ Exhaust246°/249°)
Timing @ .053 lift Open/Close:
(Intake: 19° BTDC/47° ABDC
Exhaust: 55°BBDC/14°ATDC)
TDC Lift @ valve int/exh: (0.181”/.153”)
* Theoretical based on rocker arm ratio of 1.65. Valve train components, operation temperature and tolorence stack-up will affect actual lifts.
Old Sep 9, 2013 | 07:04 AM
Capo's Avatar
Capo
From what I read it's similar to an EV 51. Could lose a little bottom end unless you bump compression.
Old Sep 9, 2013 | 08:47 AM
HGM's Avatar
HGM
Thats whats in my Dyna with 9.5:1 Weisco's and its fun.. Cant compare it to the EV-27, I've never ridden one, but it has plenty of power in a useful range. Just by seat of the pants, I'd say it may lack the very bottom end, tire smoking torque, but it comes on pretty hard and loves to run until the heads run out of air.. 80mph is very peppy and a slight twist will clear 90 very quickly.. Anyhow, thats my "feel" dyno report..
Old Sep 9, 2013 | 09:25 AM
Tee&Vee's Avatar
Tee&Vee
looks like a good to very good cam. Kushman's paste though makes me leery of it being a direct 'bolt-in'. anything hi-lift simply ain't drop and go.
Old Sep 9, 2013 | 09:32 AM
HGM's Avatar
HGM
Just to give you an idea, the dealer dropped the cam in mine years ago. The did change the pistons to 9.5:1 flat tops, but no work was done to the heads until recently.. My guess is they are bolt in cam's but need the compression to realy come to life. I'd suspect 10:1 might be more ideal, but tuning would be critical to avoid detonation..
Old Sep 9, 2013 | 03:18 PM
Spanners39's Avatar
Spanners39
Thanks guys, I think the Ev27 is better suited to his RK though.
Old Sep 9, 2013 | 03:21 PM
Scrmnvtwins's Avatar
Scrmnvtwins
I ran the SE-11 cam in an 89 Evo FXR with 10.5:1 forged pistons. Enjoyed the broad torque range and high RPM HP so much I installed the similar profile SE211 cams in my '03 TC FLH
nottaway
Engine Mechanical Topics
Sep 4, 2015 12:28 PM
CYCLE1949
Ironhead
Feb 19, 2014 09:03 PM
HDSAE60
General Topics/Tech Tips
Dec 16, 2013 07:57 PM
cardboard
Exhaust System Topics
Oct 2, 2010 05:15 PM
heavypic
Jul 20, 2009 05:40 PM
