Speedo change
Old Oct 3, 2013 | 11:02 AM
bluharley's Avatar
bluharley
Default Speedo change
Can an 84 speedo work on my 88? Would I need to change the drive unit? Will the 84 drive unit work on my 88? The first is my 88.
Old Oct 3, 2013 | 11:19 AM
1/2crazedbikr's Avatar
1/2crazedbikr
May be a stupid question but you're sure it's not the driver right Blu?
My speedo went out and like a dummy I removed the fairing, replaced the cable and still had the problem. Turned out it was the driver. I should've checked that first. Way easier job.
Old Oct 3, 2013 | 11:34 AM
bluharley's Avatar
bluharley
I'm not real sure. This is my story. The cable broke some time ago. Everything worked fine except the trip od. After the cable broke, I rode a while before replacing it. Ever since I put that new cable in, my speedo would read 20 when I was doing 50, something wrong there. Then, after my od turned 100k, it started going backward, until today, it stopped all together. My speedo still moves a little, but not much. What's really funny, is my auto volume control works fine! Go figure. I think it's the speedo. I just called my local stealership, and they have a drive unit for my bike, for $78.....
Old Oct 3, 2013 | 05:24 PM
1/2crazedbikr
If you've got a few days I got mine at JPCycles for about $25. Has worked fine for about 10,000 miles now.
Old Oct 3, 2013 | 05:46 PM
bluharley's Avatar
bluharley
I'm just going to do without unless I bump into original equipment, or get a speeding ticket, whichever comes first!
Old Oct 3, 2013 | 06:08 PM
1/2crazedbikr
Did the same thing for a long time myself!
Windseeker
EVO
50
May 7, 2018 09:24 PM
YeOldeStonecat
Shovelhead
Sep 18, 2014 03:17 PM
bluharley
EVO
Aug 7, 2013 06:49 PM
Blown 331
EVO
May 23, 2008 10:46 AM
janne63
EVO
Oct 3, 2007 01:23 PM
