I was googling SE ac kits, and this came up with a cross reference to the SE kit. Is it basically the same thing or not? Will it (and the SE kit) fit under the stock cover, or is the filter exposed?
The photo shows the carb side, but the instructions shows the cover side, which looks fine. Looks similar to an SE kit. The cover will hide the filter, just as it does with the stock filter housing.
Well, this looks like the SE 29008-90A original kit that you directed me to @ jwboon, but they are in the Netherlands and it will cost $170.
So, this looks like worth a try, about $100 cheaper. My issue is I have a 92 FXSTS and most aftermarket kits say 93 & up, due to the breather location on the 92 being different.
I don't know how the differences in breathers would play out, but if you'll notice in the description it cross references to 29008- 90A. JP has a good return policy, worth a try. Maybe you could fab up something for the breathers.
Looks like it will work i have a 91 softail and can only find 93 up air cleaners up to 92 breath thru cranckcase 93 up breath thru heads i might have to try this one thanks for the link
Your welcome.
This is my problem with it. JP says it will work on my bike, but it's a head breather system, and it looks like just bolts where the breather bolts go on my bike. I even talked to a tech and he assured me it would work on my bike.
O/k, found the RevTech kit # 59-215 on E-bay, $45 shipped. Figure for that price it's worth a try.
I just did the Andrews 27 cam in my 92, have the original exhaust with the old S E SlipOns, had the original carb re-jetted. So, the stock a/c restriction was the only issue, hope this kit is right and fits.
The old 92 EVO should run real nice now.
O/k, RevTech kit fit well, seems to be a correct replacement for the hard to find S E kit for 92 and older.
With this kit (keeps my stock a/c cover) and the Andrew 27 cam I got that old EVO sound and it just rips!
