Carb. back fires
Old Mar 15, 2007 | 09:12 PM
Tom19461992's Avatar
Tom19461992
Stage II
Default Carb. back fires
I have a 96 Wideglide that will back fire on re-start after it's been sitting for less than an hour. It'll pop once and then start and will do it with, or without the chock on. Any suggestions would be appreciated.
Old Mar 15, 2007 | 11:56 PM
Tucker99's Avatar
Tucker99
Default RE: Carb. back fires
Are you giving it gas? I had a similar problem. I replaced the stock carb with a Mikuni and that problem and others went away. It's the best $250 you can spend and it's plug and play.
Old Mar 16, 2007 | 10:20 AM
mtnlvr's Avatar
mtnlvr
My 98 was the same way. It would also pop sometimes when doing a roll-stop right when I'd try to accellerate away from the stop. It's rather dangerous.
I tried rejetting. I did all the CV mods. I rebuilt the entire carb. I checked, but didn't locate any vacuum leaks.
I still haven't found the problem, but I'm thinking it'll be gone by the next time I start my bike. I'm in the process of upgrading almost everything that feeds the engine or lets it breathe. I sure hope that ends up fixing it.
Sorry...no direct advise, but search around for the "Harley lean pop" or some combination along those lines.
Old Mar 24, 2007 | 12:36 PM
97wideglidenh's Avatar
97wideglidenh
I had the same problem w/ my 97 big back fire (through exh,) on restart. found last owner striped the idle mixture screw when it was all the way in. I TRYED EVERYTHING!! even w/ the carb off, it was junk,, so i got one on e-bay(yes takeing a chance),,swaped my rejet kit, and a few other mods, now its fine,, it also doesnt pop when you decell then snap the gas to down shift,, hope this helps,, dave[sm=gobble.gif]
Old Apr 8, 2007 | 04:50 AM
hard_head's Avatar
hard_head
That back fire problem lies in the idle mixture screw... too leanwill make it pop through the carb. If the mix is too rich it will run good, start easy, foul plugs amazingly fast and get horrible gas mileage. Adjust the mixture screw to a little better than lean and you are tuned.... should have no more carb coughs.
Swede
GordFXE80
Shovelhead
Apr 30, 2014 10:59 AM
06hds
Oct 25, 2012 03:19 PM
ryamatt
Jul 28, 2012 03:16 PM
jinx1080
Jun 4, 2012 09:46 PM
JohnFlorida
Exhaust System Topics
Apr 26, 2011 02:33 PM
