Jet size question.
Old Jan 22, 2014 | 04:47 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Default Jet size question.
As some of you know the rebuild on my motor is finally coming together, and it won't be long before it's all back together. Before I order a kit from CV performance though, I'm not sure on what size jets I'll need with the combo I'll be running, or rather a starting place.
Here is the combo we're looking at...
I went with a V-thunder 3010
Paughco 1 3/4" drag pipes with lollipops
Arlen Ness big sucker
The carb right now is running a 45 idle jet, and if I remember correctly, a 175 main jet. I'm thinking of starting with a 180 main jet, and if that doesn't work stepping the slow jet up to a 48? I know I won't know just quite what I need until I ride it, but I'd like to know what you guys recommend as a good starting place.
Old Jan 22, 2014 | 05:39 PM
johnjzjz's Avatar
johnjzjz
when you add a hi flow jet tube and needle that comes with a performance kit / we find you need to go down on the jetting --
i would pose this question to whom you are buying the kit from - they should know if they dont - than buy the kit from someone else -- johnjzjz
Old Jan 22, 2014 | 06:14 PM
HarDlife's Avatar
HarDlife
I'm running a 46 slow and 180 main w/ a velocity needle and emulsion tube, all CV Performance.
My setup is 10:1 wisecos, VT 3020, drilled out ac w/ hp filter, se slip on's, and se module. Runs pretty good w/ this setup, but has a very slight bog/hesitation from cruise to WOT. When I had the 45 slow jet in the bog was not there, very responsive, but the plugs looked totally clean. At that time I didnt have the emulsion tube or the 180 main in, so I think I'll go back to the 45 and leave everything else the same.
I think with your setup I would leave the jets alone, and use the velocity needle and emulsion tube as well. Since they are so cheap I would get 1 size up slow and main (46/180) just in case you need them. I would recommend getting their ez adjust for the idle mixture also, makes it much easier.
Since we have similar bikes and live at basically the same elevation, I would imagine your AF requirements to be somewhat alike.
Old Jan 22, 2014 | 06:25 PM
tmanbuckhunter
Yeah... I don't know if you've been to Tallahassee but it can get pretty hilly up here in the pan handle and south GA, but it can't make that much of a difference. I was hoping to get some input from you, thanks!
Old Jan 22, 2014 | 11:00 PM
cowboy 51's Avatar
cowboy 51
When you order from CV Performance , email them all you build spec's & they will know just to send you Jet wise include your exhaust style ,& CV P will set you up
Dally-44
EVO
16
Apr 11, 2012 03:07 AM
ccondon23
Exhaust System Topics
Jul 28, 2007 08:45 PM
outfishin35
May 30, 2007 12:19 PM
02spty1200c
Feb 14, 2006 12:31 AM
99FXST
Feb 10, 2006 02:06 PM
