Top end gaskets
Old Mar 18, 2014 | 03:15 PM
SteddyTeddy's Avatar
SteddyTeddy
Default Top end gaskets
Getting ready to pull the top end and freshen it up. 96k miles and hearing some piston slap when cold. The plan is to go back with 8.5:1 pistons at .010" over. My question is which top end gaskets to get? Mainly what type of head gaskets and how thick? MLS, teflon, carbon? .030", .040" or .045"?
Old Mar 18, 2014 | 03:41 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I went with Cometic.
Old Mar 18, 2014 | 04:04 PM
SteddyTeddy
I use Cometic's on my Kaw builds. Good gaskets. If I go with the .030" kit, anyone know how much of a CR bump I'll get? Not sure what the stock thickness is.
Old Mar 18, 2014 | 04:11 PM
johnjzjz's Avatar
johnjzjz
the difference is almost .2 on the 8.5 so maybe 8.7 .042 verses .030 but it depends on deck height and you being stock that is about right with out a cam like EV 27 it causes more strain on the battery and starter
we only use cometic MLS today even if a customer brings us gaskets we throw them away - if you plan on removing the paper ones yourself you will see why we do that -- johnjzjz
Old Mar 18, 2014 | 05:19 PM
SteddyTeddy
It has an EV13 in it now.
Old Mar 18, 2014 | 06:00 PM
HarDlife's Avatar
HarDlife
Stock is about .045
Like john said going to a .030 will only bump your cr up about .2, no big deal, but every little bit helps w/ the weenie stock compression. Although your not losing much, if any compression with that EV13.
Cometic MLS is the way to go as far as brand.
Old Mar 18, 2014 | 07:23 PM
Schex's Avatar
Schex
I just measured the old gaskets that came off my '97 softail and they are .050.
If your deck height is zero or in the hole, which it probably is, you can go with the .030.
Old Mar 19, 2014 | 07:26 AM
falconbrother's Avatar
falconbrother
I used HD head gaskets. Actually, I used HD for everything but the base gasket which was Genuine James.
Old Mar 19, 2014 | 07:42 AM
johnjzjz's Avatar
johnjzjz
Originally Posted by HarDlife
Stock is about .045
a point of info - short duration cams trap static compression better than long duration cams do - that is the compression that the engine actually compresses after the intake valve closes
lots of other info is also at work but that is the idea - So an EV 3 has more low speed grunt than the 27 but it runs out of breath earlyer in the PRMs - and the 27 make more power higher in the revs < all it really is is an air pump the more you take in the more you get valve opening and length of time open determins how much power
just plain john
Engine Mechanical Topics
Dec 30, 2019 06:02 AM
86glider
EVO
Apr 10, 2018 03:56 PM
northeastconfederate
Exhaust System Topics
14
Jul 14, 2011 06:54 AM
no1_3fan
Feb 1, 2010 06:25 PM
harris48cars
Mar 15, 2006 11:46 PM
