Redline Heavy Shockproof?
Old Apr 6, 2014 | 06:43 PM
Matt K's Avatar
Matt K
Default Redline Heavy Shockproof?
I'm looking to change the fluids on my 99 Fat boy for the first time. I've decided to put Mobil V twin 20w50 in the engine.
For gear oil, does anyone run the Redline gear oil? Do Evos respond well to this gear oil? The P.O. currently has Bel Ray 85w140 in it. Should I just stick with that?
Thank you
Old Apr 6, 2014 | 06:45 PM
aces&8s's Avatar
aces&8s
Short answer, yes.
Old Apr 6, 2014 | 06:50 PM
nanaimohd's Avatar
nanaimohd
I have used it for along time ,I like the fact that it is a different color making it easy to tell if the trans , primary or engine oil develops a leak .. .I have not noticed any performance difference other than on my 2008 Streetglide on that bike it made a big difference in finding neutral compared to the factory oil.
Old Apr 6, 2014 | 06:52 PM
Matt K's Avatar
Matt K
Originally Posted by aces&8s
Short answer, yes.
Yes to using the Redline or to sticking with what the PO used?
Old Apr 6, 2014 | 07:07 PM
1997bagger's Avatar
1997bagger
Shockproof heavy
Old Apr 6, 2014 | 07:18 PM
traildog's Avatar
traildog
Originally Posted by nanaimohd
I have used it for along time ,I like the fact that it is a different color making it easy to tell if the trans , primary or engine oil develops a leak .. ..
DITTO! Shockproof top, ATF primary bottom.......
Old Apr 6, 2014 | 07:23 PM
craving94509's Avatar
craving94509
Yup. Use it and love it.
Old Apr 6, 2014 | 08:27 PM
Matt K's Avatar
Matt K
ATF is referring to Royal Purple oil?
Old Apr 6, 2014 | 08:30 PM
traildog's Avatar
traildog
Nope......Castrol Automatic Transmission fluid
Old Apr 6, 2014 | 08:31 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
No ATF stands for Automatic Transmission Fluid.
Available at your nearest auto parts store of your choice.
