Ok, got my ignition in, not sure on the installation.... anyone that's has installed this , HELP! I read the instructions...not sure what I am even reading! Are ya'll using the voes switch like it says in the instructions? It says the voes switch is suppose to be violet,doesn't look violet to me! BUT, I'm color blind also! I hope I didn't mess up, but I assume you are suppose to cut the 3 wires to the original plug and just solider the new wires to the old switch?
as you see in the pic..the red wire that I have twisted to the violet wire, the instructions are saying that red wire is suppose to be violet too.
One other thing..what the hell is single fire/dual fire crap??
We just run the wires to the center post of the coil(power) then to each side of the coil, and right to the VOES switch. We dont use the original wires except for the power wire. The original wires go to an ignition module!!
So the original ignition plug is not used? And as far as the voes, I hook it to the the plug off the frame or the plug or the actual switch? I cant tell which wire is what color on the voes ... and that yellow plug down there, just leave it unplugged?
I had some difficulty with mine too. Call the company. THey have techs there that will walk you through it. They do this everyday and they want to help.
Ace, where is that white single wire on the top right come from?
Your Dyna Kit should have this same diagram. The White wire is the original hot wire to the coil and also hooks to the white wire to the ignition. I have talked to the Dynatek people in the past and they are very helpful.
