Does anyone know what could be causing...
Old Apr 26, 2014 | 10:24 PM
AAAC's Avatar
AAAC
Default Does anyone know what could be causing...
my speedometer to be jumping around while it's sitting still and idling? It will sometimes jump up to 10-15 mph while sitting still...just kind of randomly. It's an aftermarket gauge set. It kind of makes me wonder if I can trust the speedo or the rpm gauges. Thanks!
Old Apr 26, 2014 | 10:49 PM
PanHeadRich's Avatar
PanHeadRich
What year's the bike? I'm guessing from your description that it's electronic driven Tach & Speedo with the magnetic sensor? If so, it's probably the magnetic sensor (screwed onto the trans) that's failing. I've had to replace mine a few times on the 97 Springer.
If they're cable driven, disregard the above, I don't have a clue.
Old Apr 26, 2014 | 11:44 PM
cowboy 51's Avatar
cowboy 51
If it's elect try cleaning the end where it hooks to the trans , they can get dirty , I just pull it & wipe it off with a clean rag & good to go
Old Apr 27, 2014 | 07:00 AM
traildog's Avatar
traildog
+1 on this solution. Mine had all kind of crap stuck to it before I cleaned AND waxed (jk) it....
Old Apr 27, 2014 | 07:57 AM
johnjzjz's Avatar
johnjzjz
i see part of the inner left side lower race directional thrust washer end tang on that
Old Apr 27, 2014 | 08:11 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Sometimes an electric speedo malfunction is a warning sign that the transmission is making metal.
Old Apr 27, 2014 | 08:52 AM
johnjzjz's Avatar
johnjzjz
the ultimate washing machine effect starts out slow then spins everything into a ball
Old Apr 27, 2014 | 04:45 PM
traildog's Avatar
traildog
Huh? The stuff that I wiped off was "greasy dust."
Old Apr 27, 2014 | 05:03 PM
AAAC's Avatar
AAAC
It's a '97. I think it's electronic. It's a brand new gauge. It only had about 100 miles on the new gauges.
Old Apr 27, 2014 | 06:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If it is a '97 then it is electronic.
