upgrade lighting
Old May 9, 2014 | 06:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Owtlaw
Sounds like a bad ground feeding back through the passing lamps.
That doesn`t even make sense. A bad ground is a bad connection, nothing more. There is no bad ground feeding back through the passing lamps.
Sorry for the rant, but there is too much junk science passed around as fact when it comes to electrical circuits.
If the lights are dim, they are not getting enough voltage, and the stock setup has that drawback designed into the system.
If the passing lights do not go out when hi beam is on, the wiring has been altered.
The best way to get full voltage to the lights is to use a relay and draw power directly from the battery instead of drawing power through the dimmer switch and through who knows how many connections.
Old May 9, 2014 | 07:13 PM
rivercityslim's Avatar
rivercityslim
Originally Posted by texashillcountry
Or you could do something like this
Apron Project - Darkside Scientific - YouTube
That's actually a pretty cool idea there.
Old May 9, 2014 | 08:56 PM
Owtlaw's Avatar
Owtlaw
I had a situation where I would sometimes lose the headlight and dimly illuminate one turn signal lamp and its indicator on the dash. Improving the ground to the fairing fixed it. His passing lamps, when turned off, are dimly lit. I think the headlight is losing ground and grounding through the passing lamps.
Costs nothing to run a separate ground to test it.
Old May 9, 2014 | 09:19 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The passing lamps are powered by the low beam circuit. When the hi beams are on, the low beam circuit does not have power.
There is no path for power from the high beam circuit to the passing lamps.
If the passing lamps are dimly lit, it is because there is something wrong with the wiring, or it has been altered.
Old May 9, 2014 | 09:34 PM
Owtlaw's Avatar
Owtlaw
I'm sure you're probably right. No sense in checking the ground then.
Edit:
Here's a thread from an unrelated forum about the same phenomenon with a poorly grounded trailer.
http://www.automotiveforums.com/t224...h_w_break.html
I'm back to saying my money is on a ground issue.
Old May 10, 2014 | 07:35 AM
Dr.Hess's Avatar
Dr.Hess
Well, the OP's problem, not the seeking an upgrade issue, but the problem, I think could be the ground but could also be a connector or the switch. hoghead, when you checked the voltage at the headlight and spotlights, what did you use as the ground point? Also, take an alligator clip lead and ground one end to something really, really ground, like the battery negative, and then touch the light bar with the other end. Does the weird behavior change? Touch the ground wire of the headlight. Any change? That would rule out ground problems in that circuit. Measure the resistance from the battery negative to the engine case just for the hell of it, and to the light bar. Jumper from the battery positive to the headlight low beam +. If that makes everything bright, switch/connector.
Old May 10, 2014 | 07:46 AM
hoghead5150's Avatar
hoghead5150
thanks guys. dr. hess that is what i will start with when i get back, we are taking a weekend trip to eureka springs.
when i did my testing i grounded to the headlight bucket and the passing lamp buckets. the grounds for the passing lamps are riveted to the inside of the bucket so i tested there.
to clear up, when i switch to hi beam my passing lamps do NOT go out, BUT they DIM way down. i'm getting 4.5-5 volts to the passing lamps when on HI beam.
another thing, IF i disconnect either one of the passing lamps the entire system works as it should. headlight and hooked up passing lamp bright, when i switch to high beam the passing lamp goes completely out.
Old May 10, 2014 | 09:35 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That leads me to believe that whatever the stock system uses to shut off the passing lamps when you turn on the high beams is not working correctly.
At a guess there is a relay somewhere in the system that is no longer operating as it should.
It could also be that someone tried to rewire it sometime in the past (as already suggested) and they did a bad job of it.
Do you have the electrical schematics for your bike?
Old May 10, 2014 | 03:14 PM
Dr.Hess's Avatar
Dr.Hess
If you're going to Eureka Springs, stop on by. In near Fayetteville. I'll take a look at it.
Old May 10, 2014 | 05:40 PM
Tee&Vee's Avatar
Tee&Vee
Hh5150,
The guy offering you help redid h his top end in a motel parking lot on a road trip with his wife. I'd take him up on his generosity!
