Stumped?
Old Aug 17, 2014 | 04:50 PM
Dr.Hess's Avatar
Dr.Hess
Just take off the old one and put in the Pingle. Buy the Pingle that matches the configuration for what you have: 90 degree, straight, etc.
Old Aug 17, 2014 | 06:07 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
It is really easy.
The hardest part is figuring out what configuration you need and you can look at your old petcock and get that information.
Old Aug 17, 2014 | 09:39 PM
MJHJEA's Avatar
MJHJEA
Sounds too easy......I'll give it a shot
Old Aug 17, 2014 | 11:28 PM
MJHJEA's Avatar
MJHJEA
Hey what am I getting for another 100 bucks with pingel vs oem replacement petcock? Just getting ready to order.
Old Aug 18, 2014 | 12:36 AM
indiablue's Avatar
indiablue
I have a Golan and I love it. The positive click detent for the positions makes a big difference. Not so much because it performs so much better but just in how it feels (a lot heavier/ beefier). You just need to reach down and use one finger to change positions. Because of my 7 gallon tanks that makes a big difference with my reach and the lever swings on a horizontal plane rather than in the stock vertical manner. Rebuildable if you ever need to replace an o-ring. BIL has a pingle. It works fine but feels weird to me. My 2 cents
Old Aug 18, 2014 | 07:34 AM
texashillcountry
Dirt don't hurt
Your getting a petcock that works 100% better than a stock one.
It flows more fuel than the stock one and is much easier to operate even with winter gloves on.
Old Aug 18, 2014 | 07:38 AM
grbrown's Avatar
grbrown
Red face
Tis a thing of great beauty - almost a shame to put it on a bike! It is way over-engineered for our street use, but gets around installing a petcock in an EFI tank (in my case).
Old Aug 18, 2014 | 10:28 AM
MJHJEA's Avatar
MJHJEA
Figured it was probably better quality, didn't mean to doubt you guys. One last dumb question....the pingel is high-flow I see. Is there any difference in performance or gas mileage after install?
Old Aug 18, 2014 | 10:30 AM
MJHJEA's Avatar
MJHJEA
ei. have no clue how it differs from stock other than quality as mentioned
Old Aug 18, 2014 | 10:32 AM
grbrown's Avatar
grbrown
Wink
None at all. It is able to provide a higher flow rate than a stock tap, but only a very modified engine is likely to be able to use that. It will feed gas to a normal road engine at the rate the carb/EFI demands it.
